2000 S430 Wont start - please help!
Old May 24, 2006 | 03:00 PM
beckel's Avatar
Hey guys,
Really goofy problem this car is having. about half the time when I go to start it up it will not even attempt to crank. I have checked most of the obvious items...new brake light swich, started using a different key, battery voltage, etc. but nothing seems to work.
I can always tell when it will not crank because if I step on the brake I will not here the usual "click" from the shifter that lets me know the interlock has disengaged.
Does anyone have an idea what might be causing this weird behavior? I am anxious to get this fixed because I do not want to be stranded.
Thanks!
Brian
Old May 24, 2006 | 04:30 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Sounds like your key batteries( 2 ) or the key is coming slightly loose when you put it in the ignition.
Old May 24, 2006 | 06:56 PM
jmiaebrown's Avatar
2000 S430
Sounds like the same thing that happened to my 2000 S430. Check the ignition coil switch. Dealer only charged me $88 bucks but they said it should have been around $300 to replace.
Old May 25, 2006 | 09:02 AM
beckel's Avatar
jmiaebrown,
when you had this problem would your car crank but not start? Mine will not even attampt to crank.
Old May 26, 2006 | 12:22 AM
Thrillhouse's Avatar
well youve already tried a second key so I give you props for that, thats most than most will even try, it has nothing to do with the batteries in your keys so dont waste your money replacing those, the key will start your car without batteries in it, the EIS sees a signal from a micro chip in the key, from what youve told me, it sounds as if your EIS is taking a ****........ you need to run some codes on it tho, is it still under warranty? when you put the key in and it doesnt start will it turn at all?
