fuse
Old Apr 19, 2007 | 11:06 AM
gac's Avatar
gac
2002 S500 black/java/2011 Escalade (wifes)
fuse
does anyone know which fuse is for the auto folding mirrors? mine stopped folding in when locking the car with the remote this past winter while they were stuck folded in due to the extreme cold. they fold in if I push the button from the inside of the car but not with the remote.
thanks for your help.
Old Apr 19, 2007 | 12:16 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
If they fold when you press the button inside then there is nothing wrong with the folding mirror circuit.
If you had them folded and had to manually unfold them then maybe the car thinks they are still folded.
Go into your instrument cluster settings and check to make sure the auto-folding feature is enabled. IF it is, just toggle it to off then back on again. then you should be okay. Also make sure you are not using a different key if you had set Key dependent to yes. because this parameter changes to whatever the setting was for the key that unlocked the car.
