LED festoon bulbs that finally work for my S500
Old May 25, 2007 | 02:42 PM
Ansonnn's Avatar
Mercedes S500 Sport
Hey guys,
After several hundred dollars ordering various LEDs to light up my license plate like the ones on the Lexus I finally found one that actually stays on without blinking every 5 seconds and without the need for a resistor. There is a good and bad. The good is that the festoon bulb that I am using is an 18LED and it is crazy bright and if you have a silver or white car is probably even brighter than the one Lexus uses for their rear license illumination. The bad thing is that there is still a blown bulb indicator but I can live with.for now till I find a way to solder a resistor to the connector, which I'll probably need to take apart the inside trunk door. Anyways, I ordered the previous 9 LED 39mm bulb from the same guy that was recommended on this forum (warden_jp) and I read that most had to install a resistor to even keep it on, but the problem end up being a overheated resistor and melted LED bulb. Well, I ordered an 18 LED 39mm from the same guy and almost hesistated to put it on (was going to use it for the interior) but tried it and I was blown away that it stayed on. The 18 LED is unbelivably bright and for $6.00 each, you cannot complain. Let me know if any of you guys need a pic of my car illuminated. I'll take one tonight. Here is a link to the bulb. Tell Warden_jp that you heard it from me. Let me know how it works out for those seeking this mod! I loved it so much that I ordered like 12 more for the interior of my S500 and X5.
http://cgi.ebay.com/ebaymotors/ws/eB...7174102&rd=1,1
I also order this for the four rear map lights. Mercedes uses a 194 bulb but the problem with using LEDs is that it's directional and the housing positions the bulb horizontally so the LED would shine horizontally and not directly down. I notice that Warden_jp just released this flank 194 LED so it should work perfectly for the rear map lights.
http://cgi.ebay.com/ebaymotors/2pcs-...7284QQtcZphoto
----Phil
Old May 25, 2007 | 02:55 PM
kenstudios's Avatar
This is good but from past experiences, these festoons burn at a higher temp and they tend to fry the wire harness so be careful and keep checking your harness. Post some pics at night.
Old May 25, 2007 | 03:25 PM
Ansonnn's Avatar
Mercedes S500 Sport
Good point. I left it on for several hours (connected battery to charger) and no increase in temp so I am assuming because of a lack of a resistor or low ohm resistor, there is virtually no heat. I'll take some pics tonight but it looks awesome. I keep staring at it at night and every time I get out of my car. Makes a big visual difference.
