Questions on wheels and tires????
Old Aug 29, 2007 | 02:48 AM
mvomhof's Avatar
I was looking at a set of 21" BMW 5 spoke wheels for my 2000 s500. I think the 20's are too small but the 22s are too big so I had thought about running the 21" BMW wheels. Would these work and would I run into any problems with the rear being a 10 inch wide and the front being a 9 inch wide?
Old Aug 29, 2007 | 11:07 AM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Hmm that's a new one BMW wheels on a Benz...
Lucky for us they won't fit anyways..
BMW's use a 5-120 bolt pattern. You need a wheel with a 5-112 bolt pattern.
Old Aug 30, 2007 | 12:11 AM
Big "H"'s Avatar
You can rims that supports both BMW and Benz, the bolt pattern will be different. However, the center cap can be change out to support either or.
Big "H"
Old Aug 30, 2007 | 08:05 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Sorry man, 21's or 22's only work on the newer W221 S-Class or BMW 7 series. On the W220 you will not be able to get the car low enough.
If you like the chuckwagon look then go for it.
