Change your fuel filter today in 10 steps or less
Old Mar 3, 2008 | 01:06 AM
tilolite's Avatar
01 S500, 01 BMW M3 Convertible, 98 Mitsubishi Montero Sport
I just changed my fuel filter in my 01 S500 with 66kmi as part of the Service B which i did myself. Here is what i learned.
The S500 is very easy (so far) for a DIY to do maintenance unlike my E46 M3. I changed the oil and filter yesterday (used gravity and one of the easiest oil change ever).
Although the car had impeccable maintenance records, the fuel looked original and was never changed before. It wasn't the easiest thing to do but i certainly would not dread doing it again.
Here is the step to follow (at your own ..legalese required)
I did not even need to jack up the car. i just parked the rear tire on a long 2x12.
1. Remove the T relay from underneath the rear seat
2. Crank the car until it dies quickly to remove pressure from the fuel filter
3. I used a cardboard to slide underneath. once there, the fuel is located next to the fuel pump. Both a within their own plastic box right before the rear driver side tire. To remove the cover, i just unscrewed the 3 plastic bolts holding it and loosen two other screw for more wiggle room.
4. Cut off the factory clamps. Start removing the 4 hoses connected to the original FF. Some gas will drip during this step. If you were smoking before, now would be a good time to stop.
5. Connect new FF Don't forget to new clamps.
6. Replace FF relay
7. turn key to position 2 but do not start engine. While fuel pressure is building, go back to check for leaks.
8. Put everything back together
9. Start car and you're done
Did that and the car is running, no purring is more like it. No codes whatsoever.
Old Mar 3, 2008 | 09:29 AM
westcoast5's Avatar
2000 S430
nice write up, you did happen to take anypics did ya?
Old Mar 3, 2008 | 01:31 PM
tilolite's Avatar
Here is a link with pictures but done by someone else. The is an E320 series but the procedures are exactly the same. He even smartly used clamp to stop gas from driping but did not release fuel pressue by removing the fuel relay which I recommend. From underneath the car, the W220 and E320 are the same as far as the fuel filter is concern.
Overall, very easy mod.
http://www.benzworld.org/forums/w210...ht=fuel+filter
