PSE pump for W220 (door soft close,trunk close & open,seat lumbar support)
Hi,
I have a used PSE pump for W220 that order from ebay !! My Dyhamic seats was NOT wroking, I also try to pull the fuse and disconnect the battery, but will NOT work even for a min, beacuse someone said it will work a while after doing that, so I order the pump, but still NOT working,later I found out thats is a tube leaks air, NOT the pump. So make sure if there is leaks or not on your system. This PSE pump support the air for your door(soft close), trunk(close & open) and your Dynamnic seat, Lumbar support &Massage,side bolster adjustment.
I want $220 shipped. local pick up for $200. I am in S.California( Irvine, Yorba Linda, Walnut,Covina). Paypal or cash thanks.
PSE Pump
Hi, do you still have this pump available, I am local and really need one. Thanks!
Doug Hay
858 877 0780
hay@doughay.com
Doug Hay
858 877 0780
hay@doughay.com
