My Comand 16x9 facelift retrofit on my S55 AMG.
Old Jul 20, 2011 | 01:41 PM
  #51
classyS's Avatar
2001 S430
hi gang, just wanted to post this picture in reference for command pinouts:
note to C pinouts as needed for swapping of pins
Old Jul 20, 2011 | 01:52 PM
  #52
classyS's Avatar
2001 S430
2003 command rear pics -
Old Jul 20, 2011 | 01:55 PM
  #53
classyS's Avatar
2001 S430
and http://www.mercupgrades.com/COMAND+FAQ-faq-1.html for command 2.0 and 2.5 pinout changes.
Old Nov 2, 2011 | 01:33 AM
  #54
cmpcpro's Avatar
2004 CLK 500
Hi there, I am trying to do this swap and have found a head unit locally.. The number is A2208205989 and your part number is A2208205889.. is there a difference? I don't want to buy something that won't work.. Thanks!
Old Nov 2, 2011 | 04:38 AM
  #55
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Only difference is yours is for US market.
Old Nov 2, 2011 | 06:46 PM
  #56
cmpcpro's Avatar
2004 CLK 500
Thanks Chris! I am about to tackle this job in the next day or so.. couple questions if you don't mind. I am in the US so I can't get a speed signal converter from you.. do you know the part number or what/where they were originally? Can I get one out of a donor car? Also, can I not use the GPS ant. that my Comand 2.5 has? I have to add another one? And if so, where does it go and can I get that from an 03 donor car?
Also if you have any part numbers that would be great!
Thanks so much!!
EDIT: I bought the unit today! Just need to get the speed signal converter and antenna, still having trouble finding out which ones I need, been looking all over too..
Old Nov 3, 2011 | 03:57 AM
  #57
I am the only one selling the speed converter. Not a MB part. Why would you not be able to buy it from me?
No, You can not use the one you have. You must have a new on. Aftermarket or donar is ok. Just buy a Comand 2.0 antenna like in the W210 and W203.
Old Nov 3, 2011 | 07:00 AM
  #58
cmpcpro's Avatar
2004 CLK 500
Well I am trying to get this finished up without having to wait 3 weeks for a part from overseas, if you were local I would have already bought it from you.. I thought these units were on all the cars that had this unit because they didn't come built in like the 2.5..? Your saying this is a special build part?
Old Nov 3, 2011 | 08:44 AM
  #59
cmpcpro's Avatar
2004 CLK 500
Also, If I do need this converter, what is the price and availability? Also, I am looking at the 2.5 to 2.0 and there is alot of different things I don't see.. I see Ctel wake up on 2.5 but not 2.0, so what will happen with phone? I see reversing signal on 2.0 but not 2.5, and speed signal one 2.0 but speed signal left and right on 2.5.. there are many more that don't look like they simply switch over.. Any ideas? Thanks
Old Nov 3, 2011 | 10:08 AM
  #60
Yes I just said that. Only I have them. Price is on the site. Yes about 3 weeks delivery. You have the pin out in this thread. It sure aint plug n play. It is a bit tricky but it works.
Old Nov 3, 2011 | 01:08 PM
  #61
cmpcpro's Avatar
2004 CLK 500
Thanks I guess I will have to convert the price on your site.. As for the pin-out I see it on this site, but there seems to be alot of pins that don't have the same names from one to another.. Can you clarify at all? Thanks
Hey Chris, I have a speed signal left and right, do you know which one goes as speed signal? And what is reversing signal? Thanks
Old Nov 3, 2011 | 09:09 PM
  #62
cmpcpro's Avatar
2004 CLK 500
UPDATE: This was the absolute easiest mod I have ever done, it took all of ten minutes. On US cars you just need the HU and trim. The antenna for radio and GPS fit fine, there is no need for a speed signal converter, all buttons work fine, radio, CD, phone, changer, steering controls are great, everything is beautiful! All I did was change 4 wires around, that was all.. the hardest part was cleaning up the dremel dust because you have to shave the dash pretty good, it's a tight fit.. what a difference too! The phone features are WAY better! It does SMS, and it tells me the NAMES of the people who call not just the numbers, and it also shows how many missed calls I have! Also when you turn the car off and someone calls within 5 minutes the HU comes back on and so does cluster and you can still take the call! It's great! I bought this unit for $400 and am selling my old one for $200 so this was a great mod!
Attached Thumbnails My Comand 16x9 facelift retrofit on my S55 AMG.-nav1.jpg   My Comand 16x9 facelift retrofit on my S55 AMG.-nav2.jpg
Old Nov 4, 2011 | 06:40 AM
  #63
GREAT news. Yes it clearly seems you dont need the converter then in the US. This is the second time I hear it works without. Strange. Same with the antenna. Euro version have totally different comectors.
Old Nov 6, 2011 | 03:20 PM
  #64
wafflehousepimp's Avatar
02 cl500
IF I DID THIS swap today...I would go for this new unit that has it all..DVD,Navi,MP3,iPod and so on...
yo chris, whats the website for the above pic u posted above?
Old Nov 7, 2011 | 01:05 PM
  #65
I is my site actually.
Old Nov 7, 2011 | 08:55 PM
  #66
benzboi7's Avatar
1986 560 sel 2001 s500 1986 dodge ramcharger 4x4 2003 dodge ram 3500 2001 S500
looks great. i just picked up a 2001 S500, and ive been wanting to do this upgrade bad. any info on the 4 wires woud be helpful
Old Nov 7, 2011 | 11:52 PM
  #67
cmpcpro's Avatar
2004 CLK 500
You need to look at the pin outs on this page and I think page 2.. but for a US car you won't have the C1 or the round connector, all you need to worry about is C2.. The only wires you need to move are 7, can bus shield, 8 can bus low or hi, and 9 the other can bus (low or hi).. then you need to move the D2B wake up also.. all of these are on the same connector, they just need to be moved around, you will have another big connector that won't be used anymore, I am not sure you need to do this as Sunil the retrofit expert says this unit takes it's speed signal from the canbus but I did it anyway, and that is I took the green/white wire out of the big connector which is speed sensor left and moved it to the speed sensor connection on C2.. that's it! You are good to go at that point..
Old Nov 8, 2011 | 06:26 PM
  #68
benzboi7's Avatar
comand swap
thanks for the info. all of your features work i take it?
Old Nov 9, 2011 | 01:28 AM
  #69
rufusjack's Avatar
2000 S430, 2002 Ml320
Recently bought 2 Mercedes- 2000 S430 & a 2002 ML320. The head units in these seem to be pretty outdated. My wife and I have been enjoying satellite radio for some time so that is a must for us. We are used to using our iphones for navigation. Anyway....
I agree with Chris the Swede about keeping the look of the dash clean. I believe we will be the last owners on these cars so I am not concerned about resale. So I am not terribly enthusiastic upgrading to 6-7 year head unit. Is their a newer Mercedes head unit that will work that has satellite radio to keep the look better? Would like to upgrade to the same unit for each car.
Old Nov 9, 2011 | 03:53 AM
  #70
cmpcpro's Avatar
2004 CLK 500
Chris the Sweede: I started using my navigation today and it isn't reliable.. it will drop out which I am told is because the speed sensor wire.. I am told I need to find a speed sensor wire from either the ABS unit or cruise control etc., or purchase a canbus adapter that converts signal to analog.. I figure your speed control converter is a canbus adapter but maybe a more personalized one for this car.. everything on the HU works great, but I would like my navigation to be more reliable.. The problem is, I really hate waiting 3 weeks to have it shipped overseas.. do you have these in stock? I will look into shipping costs unless you have a better idea. Thanks!
Old Nov 9, 2011 | 06:06 AM
  #71
There you go..Told you it would not work without it.. Not on stock. Have to make them. Shipping would cost about $30 in trackible letter.
Old Nov 9, 2011 | 08:56 PM
  #72
cmpcpro's Avatar
2004 CLK 500
Chris,
I went through your checkout process until the end and the unit is $228USD.. that is a little priceier than what I expected but if I have to pay that I guess I have to, but I really can't wait three weeks, is there anyone in America you know of who may have one available? Even if I have to pay extra.. I was told by Mercedes that a part from Germany would take 2 days to get to the US.. how quickly can I get this unit from Sweeden?
Out of curiousity.. is there anything you know of in America I can make to do the same job? I am in the computer field by trade.. I would even pay you if you could help guide me..
Thank you,
Chris
Old Nov 10, 2011 | 07:21 AM
  #73
As I said. It has to be made first. Then shipped to me from the maker and then I ship to you. I can ship express but will cost more of course. NO ONE else have it. Trust me. And the shipping quote on the site is not always corect for overseas shipments so that has to be looked into as well. And Sweden is still spelled with 2 "e" and not 3 as you always do overseas. I wonder why? .
Old Nov 10, 2011 | 11:10 AM
  #74
cmpcpro's Avatar
2004 CLK 500
Thanks Chris, if I go ahead and order what are we looking at time wise to be built? Also, can you possibly quote me on a good shipping route.. The unit on the site comes out to $228USD and the shipping was $10 or so, now I understand the shipping to be wrong, so should I just PayPal you the payment direct and forget going through the site? Is it possible to leave a deposit to get it going and pay the balance before it's shipped? Thank you for your help by the way!
Old Nov 11, 2011 | 03:24 AM
  #75
Please PM me instead....
