My Comand 16x9 facelift retrofit on my S55 AMG.
Old 07-15-2014, 09:44 AM
  #126
kenharman's Avatar
2002 S430
I see the CD Changer goes to 2.0 2003 COMAND (looks like the 7 & 8 pin on the C1, or the bottom right + - for power from the CDC). My question is where are those + - power for the CDC on the back of the 2002 2.5 + - CDC power located so I can bring them into the C1 for the 2.0 CDC location on the C1 harness. Might you know where they are located on my 2002 S430 2.5 COMAND, please?
Read more: https://mbworld.org/forums/s-class-w...#ixzz37XounbNc
Originally Posted by Kirkyboy101
Hi I have fitted the upgrade comand to my 2000 s500 and changed pins now I got sound, cd changer, telephone, radio, all to work but stereo won't come on with ignition or go of when key is turned off, I also have no lights on comand buttons at night and steering controls don't work, I'm aware that I need speed control converter which I'm in process of ordering for sat nav but does any one know what I have not done thanks in advance
Old 07-15-2014, 09:47 AM
  #127
kenharman's Avatar
2002 S430
I am in Los Angeles Ca and boy are people not helpful, including BENZ dealer. Everyone is so afraid of being sued that they dodge questions so that will not take any responsibility, ouch. If you might know where the + - power wires are for the CD Changer on my 2002 S430 2.5 Comand unit, that's all I need. If you or anyone out there can help... great!
Old 07-16-2014, 03:25 AM
  #128
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Just look at the changer..Should be tha same colors on the wire on both ends.
Old 07-30-2014, 09:16 PM
  #129
petra0919's Avatar
w220 2000 S430
Did you have to cut the top two mounting screw locations to make the updated nav/com fit?
Old 07-31-2014, 04:32 PM
  #130
corkshoppe's Avatar
13's550/2000's430/13'gl63/'13's550/10's63
yes you do.
Old 09-26-2014, 05:00 PM
  #131
Exactly...Yes you do.
Old 08-28-2016, 07:33 PM
  #132
levitas's Avatar
Connectıon adapter for Original GPS versus new GPS
Hi, I am gearing towards to do this and start collecting from eBay
Question for GPS Antenna
I would like to use original GPS instead of aftermarket purchase. Trying to install and run cables through fittings is too intrusive.
If I make or buy an adapter cable to fit the GPS connector for COMAND 2.5 to COMAND 2.0. Would it work ?
CRC9 (or MCX. Whatever the original connector) to HRS GT5-1S grey connector. It would cost the same but it will be cleaner.
On all these discussions nobody mentioned if it was a connector problem or old Antenna is somehow not compatible with COMAND 2.0 other than the connector
Question for Speed Converter
There are 6 cables on the speed converter. Ground and 12V is obvious. Remaining four is inline for Canbus HI and Canbus Lo.
So you cut the harness one goes to the connector side the other goes to the CANBUS for each. 4 cables
Color Coding is on the device for two. In or out part is not clear
Can Lo - To C2 Connector Pin 8- What Color is connected from the speed converter ? Blue or Blue-Black Striped
Can Lo - On the Harness White cable - Which color is connected from the Speed Converter ? Blue or Blue-Black Striped
Can Hi - To C2 Connector Pin 9 Green Cable - What color is connected from the speed converter ? Yellow or Yellow-Black Striped
Can Hi - On the Harness - Which color is connected from the speed converter ? Yellow or Yellow-Black Striped
This question is asked many times, I haven't seen this answered or described in a write up. If anybody knows, I would be glad. Trial and error doesn't sound good in this case
Thanks,
Old 08-29-2016, 06:56 AM
  #133
Got the answer on the "other" place...
Old 09-02-2016, 10:40 PM
  #134
jorjoe1286's Avatar
01 s430
speed signal converter and gps
Hey Chris, would like to purchase the speed signal converter and gps antenna. Please assist!! Thanks
Old 09-03-2016, 03:38 AM
  #135
They dont make them anymore and dont plan to do so again. I think think there is ONE last one left on ebay. Thats the last.
Old 09-03-2016, 08:45 AM
  #136
jorjoe1286's Avatar
01 s430
Please assist
Hey Chris, is there a link for the converter on eBay or is there a pic of how it should look? Also the gps antennas please? Thanks for the quick response!!
Old 09-05-2016, 07:21 AM
  #137
Sold
Old 09-05-2016, 07:29 AM
  #138
jorjoe1286's Avatar
01 s430
Sold
Sold
Huh? No pics? Confused off the answer.
Old 09-05-2016, 07:27 PM
  #139
The converter on ebay was sold. There is no more and they make no more. PM and I see what I can find...
Old 03-22-2018, 03:14 AM
  #140
denzel258's Avatar
W220 320
Comand 16:9 built in W220
My used parts sources over here..I actually have a extra set laying around here... They are rare so I could not pass on the deal for a extra set..
Hello ,
i get the Comand 16:9 System for my w220
but i Need the Speed Interface to built in my
W220 !! Please help me ! I cannot buy this Speed Controller!!
Thanks for your help
Old 03-22-2018, 03:57 AM
  #141
As I said on your order. Its not made anymore... Im also desperate for it.
Old 12-10-2018, 06:23 PM
  #142
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
Before the swap..
Old AC console..
First remove this tray...
Then just losen the center panel softly..
Take out the old Comand..Trim the inside panel a bit..
Move some pins in the C2 conector and add the speed signal adapter,gps antenna and put the new Comand and wood palens in place..
Mount the new AC panel with matching chrome rings..Plug n play..
All in place..All working..
New AC with the chromerings..
What you think od the swap in my S55 AMG ?? (The AMG emblem is removed now.) I just LOVE the swap and HATE the old look...
i just pulled this command out of my 2007 GL450. Can I put it into my 2001 S500 with the D2B system? Will that actually work?
Old 12-11-2018, 03:08 AM
  #143
Navigation wont work. All else will. But it wont fit physicly.
Old 07-29-2019, 06:58 PM
  #144
ctravis595's Avatar
2002 CL500 to CL55 conversion
has anyone done the facelift center console button swap? trying to find more info
Old 08-07-2019, 01:21 AM
  #145
kojak's Avatar
05 S430 rear drive
Is it possible to upgrade any further?
Originally Posted by kathmandurocks
Wait a Minute!!!!!!! So r u saying that swapping the the navi is just plug & play excepts for some moving of pins in the plug. if that what it is then you know what
THATS AWESOME
Please tell me that what I understood is right....please
This makes me wonder if it possible to upgrade any further from comand 2.5 to whatever would be newer and compatible.
Old 08-09-2019, 11:55 PM
  #146
ctravis595's Avatar
im finishing my all-in-one thread for this for w215. may be some useful tips for w220 owners also
https://mbworld.org/forums/cl-class-...ml#post7824748
Quick Reply: My Comand 16x9 facelift retrofit on my S55 AMG.
