Help!!! Car won't go when you step on the gas!!!
Hello all...01 s 430. Normal driving today. Came off the freeway and when I went to accellerate nothing happened. I put it to the floor and it accelerated very very slowly. I can only imagine what would have happened if I was trying to cross a busy intersection with my kids...wholly cow that was scarey!!!! I pullled over and turned car off and restarted it and it worked fine for a few miles then did it again...but this time with the check engine light....uuuuuuuggggg...any ideas what's going on????
I believe you have a transmission problem.
Believing and knowing are two different things. That said, I'll bet a dollar to your donut what your problem is. And it's not your transmission. Relatively simple, actually. Not super cheap, but simple.
Your gas pedal has a sensor behind it; it sends pedal angle information to the throttle. When the senor goes bad, the pedal doesn't work. The pedal replacement is a DIY job, about 10 minutes with basic tools. The pedal itself, with sensor (its a scissors-looking assembly) is available at StarPower for $150 (better than the dealer's $300): http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories Good luck- BTW, your code should be P0402 for throttle / pedal sensor... Chris p.s. If you just want to take it to an independent, the part and labor will run you about $250 average. |
Pedals and sensors
Originally Posted by socalsounds
(Post 3911802)
Not to my knowledge- I was told by my indy that a slow to respond pedal is the first sign- mine seemed sluggish (I actually thought I had an engine tune problem!) until kickdown, until it just died. Felt like a whole new car with a new pedal assembly!
yeah definitely sounds like a pedal issue...i have seen many MBs like this.
Thanks guys...I'm going to get a code readed today to double check but I have a feeling from what I've been reading that you're correct!
p0120 is the code....still the same fix?
Something that happened to me, may not be the same but similar:
I was driving, and accelerating a good bit, and I guess I caught one of the revs a bit too soon, and it's like the transmission went out of gear. It wouldn't accelerate anymore, I had to stop the car, put it in park, and back in drive. I did a transmission fluid flush/filter change, and new transmission mounts, and I never had that problem again. Although in your case it appears that it's a throttle issue with the pedal, since I think code p0120 means that. I never got any codes. |
Yes, P0120 is a pedal sensor. You need the entire scissors-pedal assembly.
Maybe you could take the parts out of a new Toyota and rebuild the pedal? Sorry couldn't resist.
Deleted by moderator |
Base on my experience, it's your transmission may seem to be the problem...
Your experience would be incorrect, its an electronic pedal issue.
ive had the same problem happen to me about 5 times now in the past year. i step on the gas but doesnt go anywhere. it revs but seems like the tranny is out of gear. if it was the pedal sensor, it wouldnt rev correct?
No revving. P0120 is the code, and it DEFINITELY not a transmission issue. The part is readily available both new and used.
I have a E430, but my pedal does not have a sensor. Do I have something else?
Also an E430
I also have an E430 that did the same thing yesterday. I was barely able to get home. And toward the end there was a whirring noise coming out of the engine area and the engine light was on.
Press on the accelerator and the engine revs up but won't go anywhere - won't engage. After turning it off and waiting a few minutes (maybe to cool) it starts up again, and will go for a few miles then quit again. Have to go to the shop with it this week, but any input is appreciated. |
I have a E430 with the same problem. Nothing happens when you step on the gas. I replaced the accelerator position sensor, but it did not fix my problem. Could the part I received from Autohaus be bad? Or do I have another issue? What next?
Suzgems, what was the problem??
Originally Posted by suzgems
(Post 5759438)
My Mercedes Benz C200 Kompressor 2003 not moving
(Post 3911802)
Your gas pedal has a sensor behind it; it sends pedal angle information to the throttle. When the senor goes bad, the pedal doesn't work. The pedal replacement is a DIY job, about 10 minutes with basic tools. The pedal itself, with sensor (its a scissors-looking assembly) is available at StarPower for $150 (better than the dealer's $300): http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories Good luck- BTW, your code should be P0402 for throttle / pedal sensor... Chris p.s. If you just want to take it to an independent, the part and labor will run you about $250 average. I Have had the pedal changed 7 times in the last 4 weeks and the issue persists, have changed the injector mouth/head, ateator, brainbox, checked all the cables; still the issue persists. I start the car to warm in the morning, and wanted to rev it about but it won't, pedal to the floor it didn't even bulg just kept running like I was not there. Please help what else can I do, I am on the verge of selling it as scrap. |
I know almost nothing about a C200 (this is the W220 Forum), but I would concentrate on the throttle body and the wiring between the pedal and the throttle body.
When you say you’ve changed the pedal 7 times , are they new or used ?
does it work at first when it’s replaced then stops working again , or have none of the 7 pedals worked ? if they work initially upon replacement then stop working , there’s probably an electrical short that’s damaging them |
Originally Posted by tusabes
(Post 8436359)
does it work at first when it’s replaced then stops working again , or have none of the 7 pedals worked ? if they work initially upon replacement then stop working , there’s probably an electrical short that’s damaging them Mostly second hand, used pedals. They work and then fail after some distance. Almost like same day. How to find the electrical short? |
you are not doing proper trouble shooting.
Most obvious is a failed gas pedal - only replace with new, not used. |
