MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   S-Class (W220) (https://mbworld.org/forums/s-class-w220-16/)
-   -   trunk won't fully open (https://mbworld.org/forums/s-class-w220/386870-trunk-wont-fully-open.html)
GHAZAN Feb 9, 2011 06:50 PM
Most recently, when i press the trunk open, it will go to 45 degrees open and not the full 90 degrees. I then have to open the trunk fully by hand. It does close on it's own well and seals shut nicely after pushing the trunk close button.
Any ideas, did a quick search, but found most issues with vacuum seal closing. tia
tower Feb 10, 2011 06:26 AM
You have reset the sensing mechanism to stop full motion of the trunk. Its a feature of the trunk system. I believe to reset for full motion, open the trunk using the trunk opening switch in the car, but continue to hold the switch in the open position for 5 or more seconds after the hood stalls. To reset to the "half open" position, hold the switch closed for 5 seconds after the trunk is closed.
CarboyS Feb 13, 2011 08:38 PM
Also, there is an option the settings menu in the speedo that lets you choose if you want the "electronic trunk limiter" on or off.
GHAZAN Feb 13, 2011 08:42 PM
Tried holding the switch and it didn't work...I'll look into the settings menu. thanks
© 2026 MH Sub I, LLC dba Internet Brands
