2003 S600 Coil Packs
Old Jun 12, 2011 | 11:18 PM
arnoldi10's Avatar
2003 S600 Bi-Turbo
Just wondering if there is an average mileage that the coil packs go out on the 2003 S600??
Old Jun 13, 2011 | 12:54 AM
classyS's Avatar
2001 S430
i think every 1/4 mile when u run 12's lol im jokin
Old Jun 14, 2011 | 09:22 PM
s5benzo's Avatar
W221 2013 S550 Rwd, W221 2010 S550 Rwd
im guessing around 60-70k ? maybe someone could chime in.
Old Jun 15, 2011 | 08:29 AM
MRAMG1's Avatar
S600, GL450, GLC 43
MB says to replace them at 100,000 miles. I forget what service interval it is.
PS: If you had to replace them after every 12 second pass, I would be broke
Old Jun 15, 2011 | 02:36 PM
classyS's Avatar
2001 S430
i love how crazy fast 12 seconds feels like in a s600.. versus your typical honda swapped engine supercharged on the bottle
Old Oct 23, 2013 | 05:50 AM
perratt's Avatar
2003 Mercedes S600
S600 Coil Pack Failure at 160,000 kms
My S600 has approximately 160,000 km on the clock and I have just had the right side Coil Pack fail. Expensive repair with coil pack being approx NZD $3500 ex Singapore.
I assume the left side will follow in due course and likely soon.
Started with an almost inperceptible but constant slight hesitation on float to light throttle between about 1200 - 2000 rpm. Higher rpm and the hesitation could not be felt, also with more throttle the issue was disguised.
Mechanics couldn't detect the fault on computers or by driving it.
I started getting paranoid, thinking I might be the "Princess sleeping on the pea".
But you need to be in tune with the car and know how smooth a v12 should be to know somethings is wrong.
When the coil pack failed however the car shuddered violently and lost significant power. Wouldn't comfortably run at above 80km/h.
Cheers from New Zealand
Hope this helps someone.
Old Oct 23, 2013 | 02:00 PM
RedC320S's Avatar
2003S600 and 2002c320s
Mine failed at 20K miles at age 5 years. Changed both with ECU.
