Looking for some audio advice
1. Install an aftermarket 2-Din unit with bluetooth, built in nav, etc. This would require the purchase of a double din dash kit, which I see ******* is offering for $175.00 with the woodgrain finish. I know that I would loose my steering wheel controls, but that may be worth having the updated system. There is also the issue of integrating the new unit with the factory amp and speakers, however, I've read where this can be resolved by using an aftermarket 5-channel amp.
2. I came across a site that was selling what they call an OEM replacement for the W220. Here's a link to the site: http://www.cars-electronics.com/2-di...oth_p1380.html
The description says that the unit will hook up to the stock amplifier and speaker systems and retains the use of the steering wheel controls via CanBUS. This unit comes with the necessary wood trim pieces to complete the installation.
Here's where I'm stuck; If I go with option one, it seems like there will be a significant amount of modification that will need to happen, which means more $$ being spent on the actual install. I'm assuming I'd need to find a shop that has experience with Mercedes installations, to avoid any issues down the road; i.e. onboard computer problems, error messages, etc.
If I go with option two, I get a "drop in" replacement which means an easier install and less $$ spent on the actual installation. Unfortunately, the unit would be coming from overseas which would be a pain if I ever needed warranty service. I'm also not too sure about the nav system they offer. Using this option I'd only have to buy the unit and pay for the installation.
I don't want to sacrifice quality in order to save a few bucks, however, I don't want to end up with the interior of my S500 rattling due to a poor installation. If anyone can offer some advice/suggestions, I'd greatly appreciate it. All in all, what I want is a unit with a decent nav system, bluetooth, and DVD,VCD,CD,MP3,MPEG4,CD-R,WMA capability.
Thanks,
Mike
It's funny that you say the back is a MOST connection. Here I was worried that it would be for D2B only. I saw another unit that says CANBUS, which fiber optic is that for?
If this is for MOST, would reprogramming be required?
Also, would it use preexisting microphone for the bluetooth or hook up additional?
We have thoroughly tested the chinese units from Haulingan and Dynavin and written elsewhere. Bottom line.... you don't get much for a radio that costs $400 (retailed up to $800)- All of our test units failed within 90 days, in one way or another.
We have some units that are being made for us (to our specs), but nothing for the S Class at this time, as the demand is not there yet.
So far the best option for a S Class, is to get a mount, face plate, buss and harness kit and put in a Pioneer, Alpine, Kenwood , etc. Keep in mind with ALL these radios you will lose function in the instrument cluster and you WILL have to replace the amp and rewire the car a bit.
Thanks for the response. You've provided all of the details that I needed to make my choice. Last thing; does Cartronics sell the the installation kit (mount, face plate, buss and harness) ? Which amplifier would you recommend to replace the stock amp? Would you be able to provide the details on what rewiring would need to be done ?
Thanks again,
Mike
1. Install the kit and stereo.
2. Run new cabling from the new stereo to the trunk of the car. (this would be amp/head unit specific - depending on what each one required)
3. Install amp of your choice.
4. Consider installing new speakers, as the speakers and amp that are currently in the car are matched for power/performance. If you do not install new speakers, do not plan on 'cranking' the volume anywhere past what it currently can go.
Unless you just want to add a subwoofer, you really need to do a full audio system replacement. IMO if you are going to do all that, just do an Ipad install. and that way youll have an incar computer and 10 inch nav screen.
I don't think we can assume that because a unit is bad fromchina, means that all units from china are bad.
Replacing the stereo with extensive modifications and replacement of amps/speakers is way too cost prohibitive at least for me.
There are many items made in China that are good, but the bottom line is there is no magic bullet when it comes to quality. Even the Chinese can not make something of outstanding quality for prices that are less than what the raw materials should cost.
@tusabes - Best way to put it.... very correct
Mike
Mike
Cartronics, any way you can tell me how to get it at $400? At that price point, it is almost worth the gamble.
Also, so is the unit from cars-electronics from Haulingan or Dynavin or something else, and how can you tell?
Lastly, it seems there is an extensive discussion on similar Haulingan and Dynavin units for BMW:
http://forums.bimmerforums.com/forum....php?t=1512832
Just wish mercedes owners have more experience as well.
To get that price you have to order 50 units. I was using it as a example of the true cost (and they have profit in that) of the unit. They just simply stink, I can't say much more than that. Almost laughable, when you get to hold one and use it (as long as it keeps working)
Thanks,
Mike
