MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   S-Class (W220) (https://mbworld.org/forums/s-class-w220-16/)
-   -   Trunk won't open (https://mbworld.org/forums/s-class-w220/488451-trunk-wont-open.html)
mrbobby Feb 13, 2013 12:05 PM
Trunk won't open
The trunk is closed and the mechanical key won't work. The electric release in the door doesn't work. Can anyone tell me where the fuse for the electric trunk release is located?
I've looked in the 2 fuse boxes under the hood and all fuses seem OK.
If the fuse is located in the box under the rear seat how does one remove the rear seat bottom? Is it like most rear seat bottoms that release by pulling on the bottom?
All help greatly appreciated.
indymerc Feb 13, 2013 02:46 PM
hi,
is there not a panel in the rear near where your lower leg would be if sitting down?
trombone Feb 13, 2013 04:17 PM
Yes there is panel at the rear passenger seat fron side. No need to lift the seat.
wallyp Feb 13, 2013 08:26 PM
On my 2003 S430, the fuses are behind the light under the passenger side of the rear seat - just behind where your heels would be. Just pop the light panel out to find the fuses - no tools required.
mrbobby Feb 14, 2013 11:10 AM
Found it - thanks for all the replys
© 2026 MH Sub I, LLC dba Internet Brands
