doing maintenance
Old Feb 28, 2013 | 12:40 AM
bozapp's Avatar
2002 mercedes s430
doing maintenance
What is B service?
Old Feb 28, 2013 | 03:07 AM
DNA47's Avatar
Facelift GLC43
B-Service
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models, and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps, warning and indicator lamps, horn, windshield/headlamp wiper and washer systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Inspect front axle ball joints and Poly-V-belt
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
Way too overpriced if done at the stealership IMO
Old Feb 28, 2013 | 03:57 PM
bozapp's Avatar
2002 mercedes s430
Thanks a lot Sir for your time and help. Now I can stop wondering.
