S500L 2001 ABC Pump repair
I have a strange humming noise comming from the ABC Pump. Yesterday I was at an official MB Dealer, where they stated that it might be the pump bearing thats making this noise. Is there a way of taking the pump apart and repairing it? Have anyone done this?
I saw in Germany old pumps being repaired and sold as new with warranty, where you have to give them your old pump in order to buy the new one. So there should be a way of repairing the stuff. MY is 2001 prior to facelift.
Best Regards,
Svetlio
I have already done this with the screw driver and I'm hearing the noise from there... Right now i'm also thinking about the pulsation damper and want to check it out. If the sound is cause by the pulsation damper, will the vibrations be felt on the pump, or on the valve where the pulsation damper is? It is sitting at a distance from the pump, so I wanna know if the damper is defect, will it cause the noise to be recognized with the screw driver on the pump, or on itself??
Thanks,
Svetlio
I checked the pulsation dampers and there was absolutely no sound comming from them. The buzzing sound is coming straight of the pump, and if you look at it for a while, you can see it vibrating along with the sound.
If I turn off the AC compressor, it seems that the sound isnt anymore repeating in stages, but being almost continious, or even sometimes gone. If I press on the gas pedal to raise the RPM of the engine, the sound is gone. You can hear it only on Idle - at about 550-600 rpm... Anything above 800 rpm is canceling the sound.
I'm thinking if it can be a faulty bearing, so that when the AC is on, it puts more stress on the V-Belt and on the ABC Pump bearing.
What do you guys think? Are these pumps bearings repairable, or should I just change the pump?
Best Regards,
Svetlio
I just made some videos, so you can hear the sound comming out of the pump.
In the first video, I tried amplifying the sound with a "stethoscope"
Best Regards,
Svetlio
There is a thread here that talks about heating the pulley cherry hot to remove and then putting the pulley in the freezer for a period of time before repositioning it back onto the pump shaft.
Typically it is the seals that become brittle and start to allow internal leakage. I don't believe this would cause noise but more likely would show itself as losing suspension height or total drop down.
Again I am not an expert.
Yesterday I made some more tests on the car with a Star Diagnosis.
The pump is reaching the needed pressure of 200 bar, but if I set up a rodeo accutation the pressure falls down to about 65 bar only after the first 5 seconds, and the pump isn't making anymore pressure for the whole rodeo. That means, that after the first five seconds where it fully rises and lowers the car on each side - it gets to 65 bar and can't rise the car fully, so it basically sits on its tires and barely moves and inch or two(instead of moving about 5-6 inches when 200 bars are reached).
Also, when the pump's pressure falls down during the rodeo, the noise disappears and can't be heard anymore. Once I stop the it, the pressure continiously rises and once above 130 bar you can hear the same noise again. I remember that in the past doing a rodeo rises and lowers the whole car like it should the whole time. Now the pump can't hold its pressure after the first 5 seconds, so it must be of an internal leak and a loosen part inside the pump.
I'm thinking of ordering the following kit in order to try repair the pump myself:
http://www.invasionautoproducts.com/mebeabcpusek.html
To get the flange out, I should heat it to almost glowing red, so it can expand enough and get out.... In order to put it back on, the whole pump should be left in the freezer overnight so it can shrink as much as possible, and then the flange should be heated again so that it expands.
I will order the seals kit right now, but it will take a while until they get to Bulgaria...
Best Regards,
Svetlio
