Electric Water Pump
Mercedes Benz G550
Electric Water Pump
I am looking into replacing my intercooler water pump. I have been getting conflicting stories of the life span of the part can anyone clear this up forme. Also, is there a write up on how to replace the part? I have been searching the forum but have not come across a how to. Any help will be grateful
1 Post
2005 Mercedes S600, 2004 Mercedes E500 4-Matic, 2002 Mercedes C32 AMG, 2001 Trans-Am WS-6
The larger pumps may require a little retrofitting.
If you go on the Tech Talk M275 thread, member Welwynnick (sp?) has a great write up on the performance of different pumps.
https://mbworld.org/forums/m275-v12-...ion-pumps.html
Also several other threads discussing the cooling of our beasts. I get the sense that too much pump (with no other cooling circuit upgrades or expansion) doesn't do much good due to either cavitation or not allowing enough time in the radiator to disburse the heat. As far as life span, I think it varies and would be best cheked with a scanner. My C32's died at around 85k, but the one in my S600 seems to be doing just fine with 114k miles. Be aware that our pumps only activate once a certain heat threshold is reached, then it deactivates once it cools off a bit - it's not always on (which I want to figure out how to accomplish with the new CM30 without throwing all sorts of codes).
