Need Help please on Swapping an old radio to OEM command display on W220
Old Sep 25, 2013 | 01:13 PM
e_xtra's Avatar
W220 S320
Unhappy Need Help please on Swapping an old radio to OEM command display on W220
Hi guys I need a big help. I have S class W220 S320 2000. Im about to get a command display which comes with wire harness and plugs from Ebay.
My questions are that. Is it possible if I could take out my old radio and cut out all the wires and replace it with the wires that comes with a command unit by matching the colour of the wires?. I just wanna get a new interior look and I just want my CD, radio and steering buttons to work. I don't care much about the DVD or NAV.
I have been searching for the right thing to do , and been trying to find the diagrams to help me solve the problems. but im still confuse.
These below are some diagrams that I found and it looks like these are not for W220?
please email me e_xtra@live.com if there's solutions
Thank you very much in advance and thanx to mbworld
Regards
Ex
Attached Thumbnails Need Help please on Swapping an old radio to OEM command display on W220-1.gif   Need Help please on Swapping an old radio to OEM command display on W220-2.jpg   Need Help please on Swapping an old radio to OEM command display on W220-3.jpg   Need Help please on Swapping an old radio to OEM command display on W220-4.jpg   Need Help please on Swapping an old radio to OEM command display on W220-5.jpg
Old Sep 25, 2013 | 07:00 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
See http://www.mercupgrades.com and BE SURE you don't cut any orange "wires." They are fiber optic cables, not wire at all.
Old Sep 25, 2013 | 11:23 PM
e_xtra's Avatar
W220 S320
Thanx so much Skylaw i have look into it and it seems there is no wire pinouts diagram for my original Radio Tape Becker 30. all i see is they have the command 2.0 and 2.5. pinouts list. So i wouldnt know what are the wires and connector sockets to connect to if i will Swap the becker 30 to a command unit.
but anyway as you mentioned i can cut all wires but not the fiber optic right?
Thanx again Skylaw really appreciated.
Old Sep 26, 2013 | 01:36 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
all your connections will go to c2 plug c1 is not used and you b plug i believe is for your speakers, im looking for becker 30 wire pinouts if i find i will help. look for my post on here i have detailed post on the pinouts i did for my radio.
Old Sep 15, 2014 | 11:13 AM
mr.money's Avatar
2003 Mercedes S430
i need help .I have a 2001 s430 and I want to up grade the radio .but I cant seem to find the after market harness to use is there a color code or something to asst me with this change on my 2001 Mercedes s430 w220
Old Sep 16, 2014 | 02:33 PM
corkshoppe's Avatar
Top Answer: 1
email me, corkshoppe@gmail.com. you don't need a new harness, you are just going to repin the c2 connector, there is a lot of write up on this from many members on here. look up mine also, but its easy.
