MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   S-Class (W220) (https://mbworld.org/forums/s-class-w220-16/)
-   -   Elec. Trunk Closer: Won't open but closes OK - Help! (https://mbworld.org/forums/s-class-w220/533740-elec-trunk-closer-wont-open-but-closes-ok-help.html)
Fraser Mar 9, 2014 01:44 PM
My 600 has the electronic trunk closer. Over time the opening function has become rather slow. It'd need a couple of tugs on the trunk release switch to open fully and lately it has only just popped and I would have to hold the button on the trunk lid for it to open fully. Curiously closing has never been an issue.
On Friday it wouldn't open at all, not from the key fob or the
trunk release in the car itself. After a few switches on and off I managed to get it to work. However when the lid shut this time after the latch clicked the system just kept whirring. I went back out to the car after a few minutes and it had stopped. I just now went to start the car and the battery is dead. I don't think it's coincidental.
I've got MB Assist coming out so I can get it to a dealer. Having a dead battery combined with electronic trunk is most annoying! Fingers crossed the electronic trunk is covered by Chrysler Maximum Care warranty, it mentions power doors which I think could include the trunk since it is a powered door.
Anyone know what could be causing the opening problems but closing not an issue (until now!)
Thanks!
kraut56 Mar 9, 2014 08:02 PM
The S600 (North America) model has a hydraulic assist system for the lid, and "soft close" for the final locking.
The system is expensive, and sold as a "single closed unit" of motor/valve, hydraulic actuator and hoses.
You can search my threads on how to refill the system with hydraulic fluid (which the MB dealer will not do).
Check if you have the same system.
ibeforreal Mar 10, 2014 12:53 AM
Have you checked the trunk closing pump located inside the trunk next to the battery. It is covered with a foam type material. Just pull that material up and make sure that the pump has fluid in the plastic cup. I use automatic transmission fluid to fill mine. If you don't see any fluid that is probably your problem. I bet the dealer will charge you hundreds of dollars to check that and fix the problem.
Hardaker Mar 10, 2014 07:34 AM
Soft closure of the boot lid not working.
I get this problem occasionally. At first it was thought to be a part and some bits were bought from scrap yards, which did nothing apart from learn a bit about how it works and waste some money. However, in my case, the solution is quite simple. Open the boot. Disconnect the battery. Leave it for a while - clean the wheels or something - then connect it back up. If boot lid now works OK you are done until the next time. I have the idea it goes into this mode if it thinks there is a problem.
Fraser Mar 10, 2014 01:14 PM
I did, when the Roadside Assist guy came out I asked him to take a quick look at the pump. We pulled off the foam and he said there was liquid in there so didn't think it was that.
Left the car at the dealer yesterday and am waiting to hear back from the SA. Here's hoping the Chrysler warranty pays off once again :)
kraut56 Mar 10, 2014 01:14 PM
To my knowledge the S320 does not come with the hydraulic trunk assist - it has an electric actuator.
Fraser Mar 10, 2014 03:16 PM
Well the dealer said they have reprogrammed the trunk closer and it works fine. The battery isn't problematic and it started up fine this morning when they worked on it me having left it for nearly 24hrs.
I'm yet to go and see it and probably won't have time until tomorrow.
tower Mar 11, 2014 07:47 AM
Outside of the killed battery, I had the exact same problem with my power assisted trunk open/closer. I also noticed that it would have more problems when it was cold outside. I read about checking/filling the reservoir so I checked mine and added a few drops of ATF without any additional benefit. What did work for me was to lubricate all of the fittings supporting the trunk lid. I had recently read about a penetrant consisting of equal parts AFT and acetone so using a 150ml veterinary syringe (with the sharp needle filed down) I proceeded to squirt some of the lube/penetrant on all the joints. Within two applications it was working great. This was after it froze up and had to be lifted by hand.
Your mileage may vary....
Tower
Fraser Mar 11, 2014 11:21 AM
Thanks for the info, tower, I hadn't thought of lubing all the parts. What's the ATF/acetone penetrant? Homemade? Would WD-40 have the same effect?
tower Mar 11, 2014 11:26 AM
In my experience, WD-40 works best for exactly what it was invented for and what the wd means "Water Dispersant". Its a light mineral based oil that evaporates very quickly. If you search in the archives you will find reference to the ATF/acetone concoction as being the best penetrant for freeing rusted/frozen nuts and bolts. It has worked for me and after the acetone evaporates, the ATF stays to continue working. Fairly cheap in comparison to the rest of the penetrant oils available.
Tower
Fraser Mar 11, 2014 03:31 PM
OK, thanks very much, I'll take a look at the other threads. The SA left me a voicemail and have said they're going to test some new trunk struts tomorrow when their order comes in. According to the tech it's not a lube issue.
Interestingly, like you, when it was cold the trunk was a lot more difficult to open, when it's warmer it was a lot easier. Sigh.
tusabes Mar 11, 2014 03:49 PM
I thought The trunk pump uses the same pentosin as the abc system , not regular ATF ?
kraut56 Mar 11, 2014 11:27 PM
This is up for debate :
On my 2002 S600 clearly ATF was used, and I replenished it with that.
Some others claim Pentosin115, but it is green, so that's easy to differentiate.
However, Pentosin 116 (red) is advertized among other uses for MB roof and trunk hydraulics (same pump) for both.
ibeforreal Mar 12, 2014 11:06 AM
Tusabes I was told by the dealer that it was ok to use ATF in the trunk pump.
Fraser Mar 12, 2014 03:36 PM
Well the struts were covered by the Chrysler Maximum Care warranty so that saved me about $95 off the $295 cost. Going to pick the car up in a few hours. :)
© 2026 MH Sub I, LLC dba Internet Brands
