Comand unit dead. Two options
Old Mar 17, 2014 | 12:45 PM
Tmarros's Avatar
2012 E63 AMG
Comand unit dead. 2.5 Direct swap?
01 S430 with it's second 2.5 comand unit (replaced under warranty) has been acting up. About 2 months ago it started shutting on and off randomly for a few minutes and then as time went on the intervals became longer until it ended up being days and weeks and now it stays off and rarely comes on if ever. I'm assuming this has something to do with the power supply to the unit but I'm also having a problem with the car not recognizing the keyfob's unlock and lock signals which isn't a major issue for me because I'm having PSE pump issues at the moment (I have left the blown fuse in there), so I only use it for the on/off of the alarm system but I'm not sure if there is any kind of correlation between the two but as of now I'm going ahead and replacing the unit.
I haven't been able to find anything on replacing a 2.5 with another 2.5. Is this a simple plug n' play?
Old Mar 19, 2014 | 11:01 AM
Tmarros's Avatar
2012 E63 AMG
Anyone have experience with this?
Old Mar 19, 2014 | 03:44 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
you might try sending a private message to CORKSHOPPE. He is very knowledgeable on the command units and the like.
Old Mar 19, 2014 | 05:06 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
it is plug and play, you got to chang out 3 pins and you can ad aux input, and get trim pieces, easy to do,
Old Mar 19, 2014 | 05:52 PM
x2nervisx's Avatar
Original poster asked if it's plug and play if he swapped in another 2.5 (not 2.0) with his existing 2.5. Is this correct? If so, then it's definitely plug and play as you're not changing any plugs or connectors. If you need another 2.5 unit, pm me as I just removed my 2.5 from my 01 w220.
Old Mar 20, 2014 | 06:13 PM
Tmarros's Avatar
2012 E63 AMG
Can you explain or link a thread on how to ad the aux Input by changing pins? I'd love to add it while I've already got it open
Old Mar 20, 2014 | 06:14 PM
Tmarros's Avatar
2012 E63 AMG
Thank you for the offer but I just bought one for $183 w/ 45 day warranty and looks new!
Old Mar 28, 2014 | 03:55 PM
Tmarros's Avatar
2012 E63 AMG
Got the new comand in and the problem persists!! After 10 mins of being on and as I'm putting the wood trim back on to the car I close the drivers door and then the comand shuts off and hasn't turned back on since. Anyone have an idea why both comand systems shut off like this?? I'm going to remove the negative terminal from the battery tomorrow and let the car reset, hopefully that will do something.
Old Mar 28, 2014 | 08:10 PM
vmystikilv's Avatar
Range Rover
Sounds like a bad ground
Old Mar 28, 2014 | 09:26 PM
Tmarros's Avatar
2012 E63 AMG
How would I go about checking the ground?
Old Mar 29, 2014 | 08:50 AM
vmystikilv's Avatar
Range Rover
Only two ways I know. With a volt meter and then you can take the + and - wire and see if you have "current" to which power can flow. Think of electricity like a river and your electronics are basically a water mill. No current no turning on. Another reason you want clean good power but that's another story.
Second way and poor mans way, especially since I lost my volt meter is to use some wire and manually apply the + voltage to the + pins and - to the negative pin. Your diagnosing to see which is bad so do only only one at a time. When it fires up , if it's the ground, you can either trace the wire and fix it, redo the cars ground point totally , our just run a new ground yourself. I have a really long wire and just come straight off the battery when testing. Also my test wire has a fuse line built into it also. Makes things a little safer but I have used regular speaker wire at friends houses when I use to help them diagnose . Good luck
Old Mar 29, 2014 | 10:37 AM
Tmarros's Avatar
2012 E63 AMG
Thank you for the detailed response! I have a volt meter from wiring my previous vehicle a few times for a sound system so I have a decent understanding on wiring and what not. I'm just unsure of which wire is the ground, any idea on how much time and hassle changing the ground can be?
Old Mar 29, 2014 | 12:46 PM
vmystikilv's Avatar
Range Rover
there are quite a number of diagrams that will tell you the pin out to easily find ground. Now, finding out what the ground is bad and where it goes, little bit difficult but shouldn't be that much.
Creating new ground. super simple and quick. I would further diagnose and find the original ground though as that may be the route to a lot of other problems you could be potentially having.
Old Mar 30, 2014 | 10:04 AM
wallyp's Avatar
2003 S500 2007 GL450
DIN Standard for Earth (Ground) is Brown. Solid Brown is a solid ground, Brown with a colored stripe is usually a switched ground.
