W220 Wheel fit help
Old Mar 25, 2014 | 07:16 AM
ajharrisw220's Avatar
2002 S430 W220
W220 Wheel fit help
I have a 2002 S430 and I just purchased some new wheels, they are Mandrus Millenium 18X8 in the front and 18X10 in the rear. I'm going to be running 245/35/18 front and 275/35/18 rear. Will I have any issues fitting these on my car?
Old Mar 25, 2014 | 08:42 AM
tusabes's Avatar
Mercedes
Correct size is 245 45 18 front and 275 40 18 rear
You'll gave too much gap in the wheel well with your sizes it will look funny unless you lower it
Old Mar 25, 2014 | 08:51 AM
2002 S430 W220
Thanks, really appreciate the help
Old Mar 25, 2014 | 10:40 AM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
You didn't say what the offset of your new rims are? You can use this tool to get the correct tire diameter based on the original stock size. You can also get a sense of how the rims will fit in the wheel well if the new rim offsets are different than the 44mm-46mm of the stock rims. If you do not have a close match then your speedometer won't be accurate.
