Brake rotor ?????
Should I go to the car stealer for pads and rotors or is there something out there that's a good direct fit. My local guy has pads rotors and sensor in stock for 160.00
I'm hoping this should fix my issue
Thanks for any input
A ridge on the edge of the rotor isn't unusual - the rotors do wear, and eventually need replacement. There will be a minimum thickness specification cast or stamped into the rotor - a quick measurement will tell you whether you are down to the minimum. Warpage or hard spots require replacement regardless of thickness.
