Limp Mode: Do any places rent out a DAS scanner?
I had it towed home and I see the leak is coming from the back of the trans pan, not sure why but all bolts are torqued. I checked the fluid level and it is still between the marks at 80 deg C on the dipstick so not low or overfilled.
Do you know of any place I can rent a DAS/Star scan tool to reset this out of limp mode to see if it comes back? Also, any ideas of what could be causing this. The only code from the OBDII is P0715.
