S320 CDi just bought..!
Just bought a 2002 version of the above and have a couple of issues which i'm hoping someone can help with!
1) the drivers door mirror (UK) has ben twatted and the reflector damaged. In addition, the mirror doesn't self park - theres a noise in the mirror asy but it doesn't move! I want to replace the reflector and fix the self park which I'm guessing requires removal of the mirror body. How do i do this?
2) the ac doesn't come on ie when you press the button, the light doesn't go out and the ac doesn't come on. Any obvious checks to make? Ive pressed the schraeder valve to check for gas and there's some in there.
3) the tensioner unit for the belt drive on the engine is a little out of alignment. Is this a simple swap?
Cheers chaps!
Steve
