connected the BT puck, where's the passkey?
Old Feb 16, 2016 | 10:03 PM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
I just connected the blue tooth puck b67876131 and I don't know where to find the passkey? My phone finds it no problem but when it asks for a passkey, I don't know what to put, I've tried 0000,1234...etc
Old Feb 16, 2016 | 10:34 PM
bigmyself's Avatar
2005 S55 AMG, 2005 S500
Mine has the key inside of top cover. On the other side, slide cover out and check. You can see the numbers.
Old Feb 16, 2016 | 10:41 PM
You have the same one, all black? There's a silver one that I know slides, but you're saying this one slides to? By the release button or the bt pair button?
Old Feb 17, 2016 | 07:50 AM
RichM's Avatar
2 2001 E320s, 2005 E320 4Matic
Try 62872 (MBUSA)
Old Feb 17, 2016 | 08:32 AM
wallyp's Avatar
2003 S500 2007 GL450
As Rich says, the standard key is 62872.
Old Feb 17, 2016 | 04:36 PM
Quadrobenz's Avatar
'94 SL600,'05 SL600,'06 S65,'07 E63,'14 E63S,'09SL600 all sold, ‘15 S65,‘18 E63S,'17 SL65, '17S65Cab
If you need them the pairing instructions are online at wireless4mb.com. As RichM and wallyp stated the pairing code is MBUSA, 62872.
Old Feb 17, 2016 | 10:09 PM
got it, thanks guys... Got the bluetooth, got the new navi maps, all I have to figure out who to hook up SAT radio? Where do I get the SAT RADIO PIN #, when I press the SAT button, just says SAT not connected? Do I need a separate module?
Old Feb 18, 2016 | 01:34 PM
eldos1's Avatar
06' W220 4MATIC (sold) 08'ml63 AMG
Some years are more wired than others for factory sat radio.
If your system says that it is not connected, then you will need the whole sat system. This is the receive module, Trunk mounted antenna and MOST fiber optic jumpers. Some years had the jumpers, but had a bypass loop installed to keep the "Fiber optic ring" intact. MB dose not stock new kits anymore. You will need to find the parts used or New old Stock.
I did do my own install on my 06' s500. It is so nice having the factory system integration.
The factory Sirius module (box) is the 2208201797 unit. It was used also in E class and others from that time. You can get the used parts for around $300-$400. New, the system was $1200+ for parts plus labor to install.
Old Feb 26, 2016 | 01:55 AM
So like mid 2000 models? W211, w220...etc pretty much cars with the command? Where does it sit, drivers side trunk area?
Old Feb 26, 2016 | 03:09 AM
eldos1's Avatar
yes, on a w220, it sits with the nav system.
Old Feb 26, 2016 | 08:44 AM
So I need that Sirius module, antenna and what else? Wiring from the radio to the trunk or is it already pre wired? I have an 05 S600 with the SAT button
Old Feb 26, 2016 | 09:44 AM
eldos1's Avatar
Starting a new thread
