Gear/abs/esp/hard steering problem s320
In the snow i had some wheelspin and abs/esp was working as it should. but the problem occured mutch later on that day, after about 1 hour drive, and a small hour brake. is there any way i could test the abs sensors with a multimeter ? is it a higher chance it is the sensor on the calliper that has been hanging thats broken ? is there any use in discoecting them all and washing them ? any help would be apriciated, iv gotten very good help here before.
Thank you !
edit: voltage was 12.2 before charging and 12.6 charged so i guess thats fine ?
Also, the speedometer is still working fine, does that tell me anything if its rear or front ?
Find the first cable connector outside the wheel arch and measure the sensor resistance - its typically 1.6 k ohms.
Alternatively use an OBD2 code reader and decode the fault codes.
Nick
