Do I have a blown head gasket?
Old May 17, 2016 | 10:26 PM
DGS430's Avatar
2003 s430
Hello - I recently bought a 2003 S430 with 60K miles and just noticed too much grease oil by the engine. Would someone please tell me if i have a blown head gasket? Or where would this oil be coming from? The car is 13 years old... could it be because of its age? Please see pics below. Thank you!
Attached Thumbnails Do I have a blown head gasket?-img_2303.jpg   Do I have a blown head gasket?-img_2307.jpg   Do I have a blown head gasket?-img_2308.jpg
Old May 17, 2016 | 11:24 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Looks more like the valve cover gasket is leaking to me. But it's not leaking so bad that you need worry right now.
Old May 17, 2016 | 11:29 PM
ZephTheChef's Avatar
2004 S600
Definitely very normal to have a bit of valve cover seepage. Doesn't look like anything to worry about to me. Usually it's not something that needs fixed right away unless it's actually looking wet or you can smell oil burning on the exhaust.
Old May 18, 2016 | 12:41 AM
tusabes's Avatar
Mercedes
Small Valve cover gasket leak is very common , not to worry
Just add oil whenever the dash tells you to add a quart
Old May 18, 2016 | 05:01 PM
DGS430's Avatar
2003 s430
Thank you for your response! I became concerned when i saw what I have shown on the second picture, where it looks a bit wet but i guess i will clean it off a bit and just monitor down the line.
