Check stop lamp when reversing
Old Jun 17, 2016 | 06:42 AM
Paul Schumann's Avatar
2000 mercedes s430
2000 s430 all rear lights working but when I reverse into my driveway it says check stop lamp. Turn on the car and drive off and the message is gone? This us weird anyone had this issue?
Old Jun 17, 2016 | 10:25 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Check your bulbs first. Could possibly be some corrosion or oxidation.
Old Jun 17, 2016 | 10:53 AM
Jack_88's Avatar
2018 C300
Have someone stand behind the car and tell you which bulb isn't working or use a reflective surface to be able to use the mirrors to see for yourself(another car, window, etc.)
I just got done fixing my taillight after a failed cracked seal around the trunk allowed water to corrode the contact points around one of the bulbs. A fair bit of sanding later, it works as good as new. Easy, if that's your issue. It could just as easily be a burnt out bulb, but that would be obvious as soon as you pull it out, they are very easy to remove with no tool required.
