Door lock issue
My doors lock but wont unlock, I can hear the pump working for 6 seconds when trying to open or close. I dont hear any air leaking out from the door panels or the seats. i reset the pump by pulling its fuse for a few hours. Now what throw a new pump at it?
shem
Some folks have reported that the internal passages or ports on the pump can get clogged with debris, and that disassembly and cleaning took care of the issue. If you try this, do your homework, and be absolutely certain that you know how to identify and mark every electrical and pneumatic connection on the pump!
shem
The doors on the USA versions have two pneumatic actuators. The door lock actuator has to both push and pull, thus needs both pressure and vacuum. The soft-close actuator is pull only, so needs only (I assume) vacuum.
So far, I haven't a clue how this could be done with only one line to each door lock module.
shem
It gives you an idea of where to look so you don't tear all the carpet on one side only to find out that all the lines are routed on the other.the_shem, as per wallyp's clarification, you must have the soft close feature then, right? Both lines should start from the distributor box you see on the bottom right of the diagram. I don't know its exact location, I think it's in the trunk, around the left side. Will search.
I dunno lol
shem
I pulled the pump and opened it up on the bench. Grabbed my jump box and hooked the neg to the black wire on the motor. Put a 5a fuse onto the pos clamp with one blade of the fuse sticking out and touched it to the pos of the motor. It ran for a sec n popped the fuse. motor sounded good tho. I pulled the pump assy off the motor and tried again, motor spun fine for days. I took some 2k grit paper and sanded the pump parts and reassembled. works like a champ and saved a fortune. I hear even if u buy a new pump u have to get it programmed at the dealer. *******s!shemmy
