Help: changing transmission mount 2003 s600
I need to change the transmission mount on my 2003 s600. I got quoted a crazy number at the dealership. From what I've seen online it's not that hard to diy. I just haven't seen any specific instructions with the s600 ttv12. If anyone can help it will be greatly appreciated. Thank you!!
Edit: just wanted to clarify that I believe all of the V12 W220 cars used the 722.6 transmission. Not sure about the others.
Easiest "real" job ever. Just support the transmission with a trolley jack, remove four bolts, remove and replace the bush, and refit the bolts.
The S600 is the same as all the others. The transmission mount is slightly further back, as the transmission itself is slightly longer, but you'd be hard-pressed to tell the difference.
Nick
Nick
