Manual use of FM station control instead od seek function
Mercedes Benz 2003 S430
I have a 2003 S430. I recently had SiriusXM installed. I need to use an FM station that does not broadcast a signal to get max quality reception from the satellite radio. However, the seek button does not stop on a channel not broadcasting. How can I manually use the station controls to select a station not broadcasting a signal. joseph
I don't think there is a way to 'scan' thru the frequencies, IE toggle switch or knob.
Do you have the telephone dial pad? I think you're suppose to push the # key, then you can direct dial the radio frequency.
