Headlight low beams don't work.
Old 06-20-2017, 03:01 PM
j.fitz's Avatar
2004 mbz s430
2004 S430. Low beam not working. They will come on at night when the car is turned off and they are set to stay on for the predetermined time. Therefore, bulbs are good and fuses are good. Does any know if there is a low beam relay?
Old 06-21-2017, 08:09 PM
wallyp's Avatar
2003 S500 2007 GL450
I'm not sure that I understand your description of your problem, but on my 2003 S430, the lights that come on when you turn the ignition off at night are the fog lights, not the low beam headlights.
Old 06-21-2017, 09:04 PM
j.fitz's Avatar
2004 mbz s430
Thanks Wally,
In that case, the low beams still don't work, neither do the fog lights when operated from the switch. Also, neither the left nor right parking lights, front or back work when the switch is turned to the left positions. This happened all at once. They just quit working. I appreciate you trying to help. The only front lights that work are the high beams and the small running lights.
Old 06-22-2017, 01:57 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
Night/day time sensor? Change your light settings to constant and see if there's any changes
Quick Reply: Headlight low beams don't work.
