Trunk Closing Problem 2003 S500...
1999 C43
Gentlemen, I'm having an issue with my hydraulic trunk closing, I did have a problem with the pump, the fluid kept leaking out, it would work fine for a couple weeks and start acting up again.
I purchases a used pump on eBay and the trunk is now opening and closing perfectly like when the car was new....my problem is when it opens it only stays open for about 5 seconds and closes automatically, it does not slam shut or anything, it just closes as if I hit the red button.
I've tried the 10 second reset procedure, no change...this is a new problem since switching out the pump, this did not happen with the old pump when it did work.
Thanks for your help....Nick
Is it possible that both struts went bad? Hydraulic pump lifts the lid up then the struts hold the lid in place. If the struts can't hold the lid then it would fall down and close.
1999 C43
Thanks DrDoe, saw that on another thread and just ordered new struts....I'll,update once they are installed
1999 C43
Ok, pretty sure it is the struts, just went out and backed the car into the driveway so the front of the car was facing down hill a little, opened th trunk and it stayed open....no pressure on the struts when it's facing down hill.
Glad to hear. I got MB struts for the trunk last year but in hindsight, I should have went for the cheapest aftermarket brand as the money is better spent elsewhere.
1999 C43
PartsGeek had two different struts available, one set were $63 each the other were $33 ach, went with the cheaper ones, talked to a guy there on the phone and he said they will work just as well as the more expensive ones...
Perhaps it requires cross reference to struts of the same length. I would think anything would work.
I got a pair of aftermarket struts for less than 25 dollars on fleabay, Works fine.
http://www.ebay.com/itm/2x-Trunk-Lif...VY-bSn&vxp=mtr
Originally Posted by amstel78
I got a pair of aftermarket struts for less than 20 dollars on fleabay, Works fine.
http://www.ebay.com/itm/Hood-2208800...-/252468202058
They were a bit more expensive at $31.00 than the last link I posted but they work fine just as I'm sure the 25 dollar ones will also function suitably.
I had the same problem of the lid closing on its own shortly after the trunk opened. Replacing both struts with the aftermarket ones solved the issue. I considered buying OEM struts but the cheapest I could find them were around $95 a piece. Personally, I didn't think it was necessary to spend that much money on trunk struts.
I also bought other stuff on eBay for my S65 like a factory MB pulsation damper for $150.00, 24 NGK IFR6QG plugs for $249, 24 OE spark plug boots for $50, and a GPS sharkfin antenna cover for $40.
It's a used car so I if I can find low cost alternatives for non-critical parts, then I'll go that route. I will however spend the money for critical parts like suspension, brakes, and drive train components (have to replace lower torque arms, ball joints, and front rotors soon). For a car with this much power and weight, you can't cheap out on stuff like that.
Not the dealerships in the NYC or tristate area. Pulsation damper at most dealerships was over $250. Trust me. I checked.
