Cup holder housing
Cup holder housing
Im not talking about the cup holder itself, i figured out how to take this portion out. This over complicated cup holder is housed in another console with the top lid cover that has a soft close/open sliding function. How do i take this off? Do I need to take out the center console for this?
The top plate is broken and where it sits is also broken. its almost loose and the soft close and open sliding is caput
how do i take this whole thing off?
Okay. nevermind. Found it. I'll just share this here. Found from google.
1 Remove center console
2 Unscrew armrest (13) from hinges (15)
3 Unclip cup holder (12) of mounting rail (10)
4 Remove mounting rail (10) with coin holder (11)
5 Unscrew bolts (arrows) from cup holder housing (2)
6 Remove cup holder housing (2) downwards from center console (1)
7 Unclip cup holder cover (4) from side guide pins in cup holder housing (2) and remove from gate
8 Open stowage compartment ventilation flap (9) and unhook bottom actuation
9 Unclip stowage compartment ventilation flap (9) at top and bottom from stowage compartment and remove upward
10 Unclip front stowage compartment cover (7) from stowage compartment (5) and remove from side guides
11 Unclip front stowage compartment floor from front stowage compartment (5)
12 Unscrew front stowage compartment (5) from bottom and remove upward
13 Unscrew bolts (15) from hinges and remove hinges toward rear
14 Assemble in reverse order.
yeah I thought about that but the problem is that the fancy sliding cover is caput. It doesn't close properly and its very wobbly and the tabs for the wood trim cover is out. In other words, I have to replace the whole thing out.
