W220 Front heater blowing cold
Old Dec 14, 2017 | 04:50 PM
kenmac15's Avatar
2002 W220 S500
Right this is an odd one, my front heater was blowing cold tonight even though it was on HI, but as it’s a LWB I’ve got rear heater controls & that one is blowing lovely & hot, so can’t work out why one blows cold & the other hot ???
Any clues please.
Cheers
Ken
Old Dec 14, 2017 | 08:54 PM
aztechmaster's Avatar
2000 s430
Aux pump under wipers not working?
Old Dec 18, 2017 | 09:34 PM
wallyp's Avatar
2003 S500 2007 GL450
Post #4 in this thread:
http://www.benzworld.org/forums/w220...-behavior.html
Old Jan 1, 2018 | 07:08 PM
kenmac15's Avatar
2002 W220 S500
Checked & cleaned the duo valve & it's a lot better but not perfect so I think it needs a new one really.
Old Jan 2, 2018 | 09:59 AM
wallyp's Avatar
Did you check/repair the pump and motor? That is essential to get full heat.
Old Jan 3, 2018 | 01:05 PM
S430AMG's Avatar
2006 S430 AMG
I seem to have a similar issue, I did notice that switching the "Auto" Setting on the middle vent helps. I moved it to setting below it which disables the red light.
I think this issue is one I can live with though, I still get the heat from the sides (in time) and it does take longer to be comfortable......not a big deal, I'm already dressed for the weather regardless. Maybe something I will consider fixing down the line.
Old Jan 3, 2018 | 01:17 PM
kenmac15's Avatar
2002 W220 S500
No Wally I only did the valves and solenoids.
Old Jan 3, 2018 | 01:35 PM
wallyp's Avatar
If you notice, in daily driving the engine rarely gets over 1500rpm for any length of time. At these low speeds, the engine water pump doesn't move enough coolant thru the heater core to keep you warm. The small pump on the duo-valve adds enough flow to make a difference.
Old Jan 3, 2018 | 01:41 PM
kenmac15's Avatar
2002 W220 S500
To be fair it's not a bad job to do, so I'll be changing mine when the weather warms up here in the UK.
I suppose it depends whereabouts you are in the USA as to how urgent it is for you, Florida or LA not so urgent, but Minnesota, Dakota etc would be a different story
Old Jan 3, 2018 | 03:41 PM
S430AMG's Avatar
2006 S430 AMG
It's great that you are handy! I might give this a shot one day, just not in this weather.
Between 0-10 degrees F past week or 2.
Old Jan 4, 2018 | 05:30 AM
ckm1995's Avatar
tata
i think it is a good car
good car in world
