Mercedes W220 Airmatic Function or Failure?
Old Sep 11, 2018 | 04:05 PM
Tallman85's Avatar
Mercedes 190D
Exclamation Mercedes W220 Airmatic Function or Failure?
Hello All,
I am currently in negotiation stages to buy a W220 - 2003 model with 80k miles. I am concerned as the car will lower about 2 inch after 24 hours switched off. The owner is claiming that all S-class have a feature that when the driver door is open, the car will lower for easy exit/entry....is this true? Cos i think there is a leak in the airmatic system which of course is costly to repair.
Any feedback is highly appreciated
Thanks & Regards
D.
Old Sep 11, 2018 | 06:22 PM
tusabes's Avatar
Mercedes
Originally Posted by Tallman85
Hello All,
Thanks & Regards
D.
two separate things - yes a S class will release air when the door is opened , but it’s not 2 inches and not for easy entry . If that was true it would lower instantly and not after 24 hours
If the car is lowering 2 inches after 24 hours it had a leak plain and simple
Old Sep 11, 2018 | 11:51 PM
Tallman85's Avatar
Mercedes 190D
Many thanks for the reply. It is as a suspected then...so i need to reduce the price to compnesate for the repair. Owner already replaced one front air strut...probably the other one needs too.
so typically, after how many days will the car start to lower ? Or they dont?
D.
Old Sep 12, 2018 | 12:00 AM
ItalianJoe1's Avatar
2003 CL 600
A properly working airmatic system should hold level for weeks. A drop of a 1/4" or so is normal as it cools (air shrinks as it cools and the car lowers), but it shouldn't continue to drop overnight or over the next couple days. If you parked it for weeks and found a corner down I wouldn't be alarmed, but in theory if the system is working as designed, the valve block is closed and the struts aren't leaking, it won't drop.
Old Sep 12, 2018 | 12:58 AM
Tallman85's Avatar
Mercedes 190D
Yes that is what i think so too. However although the car dropped, it still remained level. So probably the leak is not coming from the struts but from the main controller?
Old Sep 12, 2018 | 01:33 AM
tusabes's Avatar
Mercedes
if it’s not just one strut that’s low , but the four corners of the entire system is in the ground , then the valve block or hoses may have a leak .
Old Sep 12, 2018 | 03:45 AM
Tallman85's Avatar
Mercedes 190D
Yes that is what i think too. thank you.
