Power steering pump issues after coil over conversion
2001 w220 s600
I have a 2001 Mercedes Benz S 600 V12 I did A coil over conversion with strutmaster struts upon doing so my power steering pump started making noise and failed soon after thought it was just bad luck ordered a new power steering pump lasted about two days and did the same thing as the first one the top where is the bearing out until it is just flopping free I have read and some other forums there are a few guys They have done a few different things I am wanting to see if there is just a way to buy a line to research it back to the power steering pump a guy name cowboyt somewhere has did it before but I cannot find his forum
I have the same car same year and and I just finished the non ABC pump swap after the same conversion. Tenzero has a great thread below for the pump conversion. Just delete the ABC system altogether by doing this.
Have you noticed a power steering fluid leak ? Maybe you or the person who did the conversion damaged something while working on it because I don't see how the power steering system and the coilovers are linked. Maybe they are though, I'm not pretending that I know everything about it.
Have you noticed a power steering fluid leak ? Maybe you or the person who did the conversion damaged something while working on it because I don't see how the power steering system and the coilovers are linked. Maybe they are though, I'm not pretending that I know anything.
You can re-route the line out of the ABC side to the reservoir return and it will just pump fluid with no pressure and last as long as any other P/S pump will. Or you can swap to the non-ABC pump with custom brackets or using the OEM brackets for an SL65 Black Series.
2001 w220 s600
More info
Can I get more info on what non abc pump I need and what or where I can get brackets
It's a shared pump for the suspension/steering, if you run the suspension side dry it will fry the pump.
Some info and links here. The part #'s I posted are for a V12 without ABC, the only application that does this I'm aware of is the SL65 Black Series.
2001 w220 s600
I’m going to look into it thank you I’ll be in touch
https://mbworld.org/forums/cl-class-...ring-pump.html
2001 w220 s600
ABC recirc
So can you please explain the recirc a little more the abc line coming from where recirc to which reservoir return thanks
rerouting the abc to resivoir
abc to resivoir?
