Misfiring when fuel tank almost empty
Old 10-16-2018, 08:42 PM
STRGLZ's Avatar
Mercedes S430 2003
Hi guys,
This afternoon I was driving my S430 on an almost empty tank (I had like 10km of range) and on my way to the gas station my check engine light came on and started to blink and the whole car started to shake and went into limp mode. I had 4 error codes, P0300 (random/multiple cylinder misfire), P0301, P0304 and P0305 (misfire on cylinder 1, 4 and 5). I went to get some gas, but the car kept misfiring for a while as soon as I pressed the pedal. I didn't want to have it towed since I got another W220 at home so I could have changed the coil packs and/or the spark plugs myself, but while driving home, the problem eventually went away but the check engine light remained on even after clearing the codes. I suspect this is due to a very low fuel tank, even though I have never ever experienced that on any car I drove (and I went many times on an empty tank). Maybe the fact that I've been keeping the tank relatively low for the past 2 weeks (between 1/8 and 1/2) has something to do with it ?​​​​​​I have never had any problem with the engine so I don't think the coils could have gone bad suddenly.
Is it possible that these misfires were caused by the low fuel ? And is it possible that I damaged the cylinders while driving in that condition ?
Thanks in advance.
Old 10-16-2018, 11:51 PM
tusabes's Avatar
Mercedes
Originally Posted by STRGLZ
Hi guys,
This afternoon I was driving my S430 on an almost empty tank (I had like 10km of range) and on my way to the gas station my check engine light came on and started to blink and the whole car started to shake and went into limp mode. I had 4 error codes, P0300 (random/multiple cylinder misfire), P0301, P0304 and P0305 (misfire on cylinder 1, 4 and 5). I went to get some gas, but the car kept misfire for a while as soon as I pressed the pedal. I didn't want to have it towed since I got another W220 at home so I could have changed the coil packs and/or the spark plugs myself, but while driving home, the problem eventually went away but the check engine light remained on even after clearing the codes. I suspect this is due to a very low fuel tank, even though I have never ever experienced that on any car I drove (and I went many times on an empty tank). Maybe the fact that I've been keeping the tank relatively low for the past 2 weeks (between 1/8 and 1/2) has something to do with it ?​​​​​​I have never had any problem with the engine so I don't think the coils could have gone bad suddenly.
Thanks in advance.
how many times did you try to clear the code ? I have to try clearing it 3/4 times before it works . You didn’t do any permanent damage
Old 10-16-2018, 11:57 PM
STRGLZ's Avatar
Mercedes S430 2003
I tried once. I was told the light will eventually come off as I drive, so we'll see. But I guess another code is going to appear if I really have a permanent problem. But is it normal for a car to misfire when really low on gas ?
Old 10-17-2018, 09:45 AM
wallyp's Avatar
2003 S500 2007 GL450
Possible, but not very common.
On many fuel-injected vehicles, the pump moves full volume at all times, and the pressure regulator manages the pressure by holding back enough flow to maintain the desired pressure. If the fuel level get low enough, the pump inlet might start sucking in a mixture of air and fuel, and this could cause low fuel pressure.
Old 10-17-2018, 09:54 AM
STRGLZ's Avatar
Mercedes S430 2003
And low fuel pressure causes the engine to misfire ?
Old 10-18-2018, 09:18 AM
wallyp's Avatar
Yes, low pressure can cause misfiring.
The fuel/air ratio is controlled by the computer based upon numerous control inputs. The amount of fuel injected is controlled strictly by the amount of time that the computer holds the injectors opened for each firing event. If the fuel pressure is correct at 55 psig, all is well. If entrained air causes the fuel pressure to drop to 25 psig, less than half as much fuel is injected in the same amount of time.
Old 10-18-2018, 09:33 AM
STRGLZ's Avatar
Mercedes S430 2003
Okay, it's all much clearer now, thanks !
You said in your first message that it's something not very common, but possible. Does it mean something is broken ?
Old 10-19-2018, 09:36 AM
wallyp's Avatar
Hard to tell from here...
Old 10-19-2018, 09:40 AM
STRGLZ's Avatar
Mercedes S430 2003
I never had any performance issue actually, if that helps.
Old 10-20-2018, 02:54 AM
tusabes's Avatar
Mercedes
Now that you have filled the tank do you have any current problems ? If not then don’t worry about it
Old 10-25-2018, 07:41 PM
STRGLZ's Avatar
Mercedes S430 2003
​​​​​​I have no problems except for the fact that the fuel seems to burn faster, but I'm guessing it's because I put regular last time I went to the gas station (yep... I only noticed when I checked at the receipt). I'm actually surprised the engine didn't knock despite the fact that it has the wrong fuel.
Old 10-25-2018, 11:00 PM
tusabes's Avatar
Mercedes
all modern cars have knock sensors that retard the timing and power to prevent knock
Old 11-20-2018, 06:42 PM
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
I know this is a bit older but I experienced the same thing...gas got low and all of a sudden the car started misfiring and running sluggish as if it was going to cut off. I ran the codes and it was P0300. I had the guy clear it but he said that it wouldn't let his machine clear it out. Though he said that when I started the car it was cleared out. I filled up the car and it started driving normal for awhile (about 15mils) and then I started to notice a loss of power when accelerating. Since then I have just parked it and went into research mode.
Old 11-20-2018, 07:49 PM
STRGLZ's Avatar
Mercedes S430 2003
How bad is the power loss ? In my case I haven't noticed any difference regarding power (though the transmission and engine acts weirdly at low speed but that because of an ABS problem), but I did notice my fuel consumption dropped considerably. I used to drive to college everyday in september with about between 8-9L/100km, now I don't go to college anymore but I did use the same road and I get about 14L/100km, 12 if I'm really lucky. I'm not sure if it's related with that one time the car misfired. The transmission takes longer to change speed, so for example if I go at 50 kph it will stay at 2000 RPM and I need to reach 60 kph for it to drop at 1500. I've been stuck with the ABS problem for a few months and I know the tranny is acting weird and all that, but I never noticed any loss in fuel consumption. At that point, it could be a lot of things.
Old 11-20-2018, 09:46 PM
Mikchek's Avatar
its pretty bad...I can put the petal to the floor and I'll get nothing for about 5 seconds...once it gets going its moves but if I stop then accelerate there is a lack of power again.
Old 11-20-2018, 10:13 PM
STRGLZ's Avatar
Mercedes S430 2003
That's pretty bad indeed. Do you still have misfires and/or check engine light ? My guess would be the fuel pump or the fuel filter since no immediate response could mean the fuel takes longer to get to the injector. It could also be the injector itself that took a severe hit. In fact, it could be lot of things. If you have your own scan tool like iCarsoft or SDS (better), I would advise you do a full scan to check for any problem. If you don't, have it checked by a trusted mechanic as soon as you can. If you bring it to the garage, have it towed.
Edit : After a second thought, it could also be the throttle position sensor. It's unlikely that it got damaged by a misfiring engine, but make sure to check that as well.
Old 11-20-2018, 10:24 PM
Mikchek's Avatar
sooo many things and its frustrating cause I just got the car. I was told that it just got new plugs in July of last year...just got Service B last month...then out the blue this happens.
How do I know if I still have misfires? The chick engine light is on but it doesn't blink any more like it did when it first came on. I honestly need to go scan it again to make sure it is the same code as last time.
Old 11-20-2018, 10:49 PM
STRGLZ's Avatar
Mercedes S430 2003
When you got misfires, you'll have a flashing check engine light, the car will start to shake like hell because cylinders can't fire in the order they are meant to (for example, if the firing order is 1-3-2-4 and cylinder 3 starts misfiring, it's gonna go as 1-2-4, making the engine completely unbalanced). You'll also get poor idling and really poor performance because the car will switch into limp mode to avoid damaging components. On top of that, you'll get poor fuel economy because the working cylinders will have to burn more fuel to get the same amount of power, AND the misfiring cylinders will keep burning fuel as well. This can increase your fuel consumption by up to 50%.
If you have your check engine light on but not flashing, itsi probably just a stored code that hasn't been cleared. Get yourself an OBD-II scanner to read the codes, you can get a good one inexpensively for 25$ on Amazon. I wouldn't go to the garage for a check engine. The loss of power is more serious though.
Old 11-20-2018, 10:56 PM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
Most likely when you ran your fuel low, you inadvertently sucked up some dirty water/gas combination lurking in the bottom of your fuel tank, clogging the injectors. Your fuel injectors may need to be cleaned or replaced, depending on damage.
Moral? Always try to avoid running with a near empty tank of gas.
RollTideW163 (11-21-2018)
Old 11-20-2018, 10:59 PM
STRGLZ's Avatar
Mercedes S430 2003
Originally Posted by rustybear3
Most likely when you ran your fuel low, you inadvertently sucked up some dirty water/gas combination lurking in the bottom of your fuel tank. Your fuel injectors may need to be cleaned or replaced, depending on damage.
Running on an empty tank is never a good idea. I learned my lesson. 😁
Old 11-20-2018, 11:35 PM
Mikchek's Avatar
yeah this is my first older S500...there is no E on the gas gauge...only R....I assume that means Reserve...I thought I still had time to put some gas in...especially since no low fuel or gas light came on.
Would it help for me to put some fuel injector cleaner in?
Old 11-20-2018, 11:37 PM
Mikchek's Avatar
ok that is what I originally experienced. I let it sit for awhile and then it ran better. After I cleared the code and filled it up with gas it ran better but after about 40 miles I noticed the loss of power. I haven't noticed any misfiring or shaking at all.
Old 11-21-2018, 12:43 AM
STRGLZ's Avatar
Mercedes S430 2003
Once the orange light for the last 1/8 is on, it is your "gas light" (see the picture attached, this is a good example of how low you don't want to let it go) and it means it's time to go to the gas station. Don't know if the R means Reserve, but that would make sense.
Fuel injector cleaner wouldn't hurt, but you should also check if they are damaged. There is a simple trick involving a screwdriver that you can try yourself to see if all injectors are at least working :
Old 11-21-2018, 01:00 AM
Mikchek's Avatar
Fuel injector cleaner wouldn't hurt, but you should also check if they are damaged. There is a simple trick involving a screwdriver that you can try yourself to see if all injectors are at least working : https://www.youtube.com/watch?v=tA_E6X4ISgQ
thank you for that info. I do know I didn’t see an orange light come on so I never got that low...I will look into the injectors & check the codes again to see if something different came up
Old 11-21-2018, 01:53 AM
STRGLZ's Avatar
Mercedes S430 2003
Then it might not be fuel related, because that means you had at least 1/8 of your tank, which is acceptable. Unless your tank is very dirty, I would say the misfiring happened because of normal wear and old parts that will weed to be replaced. Don't forget that your car is 17 years old. In my case it happened because of low fuel pressure, but it's unlikely to be the same cause for you, unless your fuel pump is bad.
Quick Reply: Misfiring when fuel tank almost empty
