S500 2003 flooded, Not start, Comand and suspension issue
Hello everybody,
i have mercedes benz 2003 s500
i face problem after passing on deep water after heavy rain, the car initially work fine except alarm in dashboard showing Display defect, rear lights all on,
i remove the positive from battery, until morning of next day i try to start it was just clicking,
after removing the carpet and following the positive line, the fuel level shows empty, and remote not respond i notice there is water and rear SAM damage, after drying the bottom of the car i connect new SAM and fuel came back and all light and remote come work fine except car not clicking when need to start, and fan go full speed, air suspension not working, I replace fan relay in right front fues box and it stop, i notice in the dash board the shifter lever position not showing
and last comand system not working as well, i inspect the rear and front prefuses near battery and under front carpet looks fine, other fuses in right and left of car also fine
any help to solve this issue
Hello everybody,
i just notice that I replace K relay with damage one that is why fan stop, i replace with working one, now i got ESP, ABS, BAS error, and outside temperature disappeared and fan go full speed, gear shifter display
**update
I remove and reconnect front right side controller and reconnect and car battery looks drains, connected to dodge charger for restarting
only clickibg sound coming
comand or TV display not working
***update
i check current draw from battery it is 7-10amps
i removed battery for recharging, it is replaced about one and half year agon
I have use dodge charger battery to start the car same issue only clicking, i remove L relay, no sound no clicking, return back restarting for two three time, only one tome I heard sound amd rpm just slightly go up and stop
one fuse box I couldn’t find yet front engine compartment fuses
please some one help
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
To start with: Always disconnect the negative (ground) cable from the battery FIRST, NOT the positive!
Obviously at 6-9A battery drain, nothing is going to work right; you have to find the source of it.
How did you measure thar drain?
The stickies on this and benzworld will help you on this.
Good luck!
Good luck!
Based upon your descriptions, there are a lot of possible problems. Let's start trying to sort them out.
A battery drain of 6-9 Amps is a serious problem - if it is real. How did you measure the current draw? Please be very specific, including the type of meter used, how it was connected, and so forth.
Is the battery fully charged? Are you disconnecting the battery earth cable between trials and tests?
Are the battery connections clean and bright? This means both sides of every connection.
If you turn the ignition, the air conditioning and headlamps all on at once, are the headlamps bright?
Thanks all,
the fuel pump relay got damage i have replaced after sam replacement
now car atarted, now the comand radio not working as well as voice control, i check rear unit i found only one looks affected by water,
A2118202385
the other
A2208204085 looks fine after opening
SRS alarm also generated
A2118202385
the other
digital multi meter, I believe some equipment that standby need to operate like airmatic pump that all cause this high current
now i have charge battery until 12.8V looks fine start and stop without problem but 12.6V showing on cluster
yes
I didn’t verify this, but yesterday i notice some display error coming and remote got stop because of one connector under passenger seat i just disconnect it and now almost all fine
yes
this i am not aware of it before, now i am doing in this way
actually no after car started normal
thanks very much for kindness
Good luck!
Good luck!
The issue now SRS alarm and comand not working,
i take to someone to test but it looks some issue in communication
*update
after removing and reconnecting fue fuses
and one connector ESP,ABS, BAS comes out again
Looking for advise
*update
Looking for advise
Please any body can help,
now more problems, front light on right side foglight and turn light not working and on left side low beam light not working i check foglight i found the bulb is find
you’re going to keep having more electrician problems because you haven’t fixed the flood issue
