Heater blower motor
If you can find a "pull-a-part" yard within a reasonable distance, it is easy to pull the blower motor and regulator, and the pair will usually be much cheaper than an aftermarket motor.
Most yards will not let you carry an auto battery into the yard. If you have a battery-powered drill or impact tool, you might be able to rig a small set of power connections from the battery to a set of alligator clips. Virtually every yard will mark the parts when you buy them, and will refund your money if the part is faulty.
