not getting any air pressure to my rear struts
Hello All
Im having a tough time with this. I went to the store and on my way back home, the bottom dropped out. I checked my relays and fuses, I replaced the Valve Block. But i still get nothing. The 2 front struts work perfectly, so im sure it's not the compressor. Can Someone please give my some direction? i just purchased 2 rear replacement struts for the rear. I dont want to continue dropping money in the wrong place.
It's probably the linkage from the rear sensor to the rear stabilizer bar. They have a tendency to rust away.
I believe the part number is #2203200032.
Here's one place online you can find it. I've never bought anything from this website....I just found the part there doing a quick search. Buy the part from whoever you're comfortable with.
Hopefully your issue is something simple like this.
Good luck.
Good luck.
