Hesitation when driving
Old Aug 17, 2023 | 07:13 AM
MBW220's Avatar
Mercedes S320
Hello, I have S320 CDI W220 (2006). my car hesitates when it’s cold but then gradually improves as it warms up. I have put diagnostic on and got the following codes -
B28/5 Pressure sensor
N3/9 Control module
N33/2 Heater booster control module
Can anyone provide any more detail on these codes?
Old Aug 17, 2023 | 07:23 AM
tim687's Avatar
CL 600 '00 5.8L V12
Try checking the fuel rail pressure with ignition on, during cold cranking and when hot
Old Aug 17, 2023 | 09:12 AM
MBW220's Avatar
Mercedes S320
Hesitation on my car
Hi I’ve Mercedes’ S320cdi 2006 w220 hesitation problem when cold start it’s gets better when warmed up , can someone tell my meaning of fault code B28/5 pressure sensor N3/9 control module and N/33/2 heater booster control module ,
Old Aug 17, 2023 | 09:15 AM
tim687's Avatar
CL 600 '00 5.8L V12
How did you pull the codes from the car? Using DAS?
Old Aug 18, 2023 | 04:32 AM
MBW220's Avatar
Mercedes S320
I used a diagnostic called iCarsoft MB V2.0 and plugged into the socket inside
Old Aug 18, 2023 | 04:34 AM
MBW220's Avatar
Mercedes S320
Hi, I used a diagnostic called iCarsoft MB V2.0 and plugged it into the socket inside
Old Aug 18, 2023 | 08:12 AM
MBW220's Avatar
Mercedes S320
Anyone else can help?
