Cost to have dealer replace PSE? (Vacuum unit for locks)
None of the door locks work and the trunk wont open. It just happened recently. Thinking it needs a new PSE unit.
If I take this to a Mercedes dealer, how much will it likely be to repair?
If I get the same unit out of a junkyard, will it work? I hear conflicting stories if it will swap in without reprogramming.
Thanks for the help.
I think it should pop back into life for a brief period.
You probably have a vacuum leak somewhere in the system, which causes the pump to go into protect mode, as it isn't designed to run for minutes at a time, but rather seconds
Look in the right rear passenger area for the floor lamp behind the passenger's heels. Pry it out of the carpeted wall - don't bother disconnecting it. Behind the lamp, find the yellow 20-Amp fuse. If it has blown, replace it with a good name-brand 20-Amp fuse. If not blown, reinsert it.
Removing and reinserting the fuse resets the PSE system. If a function works for a few times, then stops working, there is probably a leaking pneumatic actuator on that function. If a function - for example, locking/unlocking the driver's door - takes longer to complete than the programmed time, the PSE control system will quit doing that function to protect the system pump.
i bought a used 100 "working one" but did find out i had a leak in trunk release so new pump was not needed
Genuine Mercedes Vacuum Power Supply Pump; New
SKU: 1440104-2208001248 | 2208001248
Mercedes S500, S430, S600, S55 AMG, CL500, CL55 AMG, CL600, S350, S65 AMG, S600 Sedan & more$666.99
Is there an easy way to troubleshoot if it's the trunk release that's leaking?
