Unknown key
Old Jan 19, 2024 | 11:39 PM
Ethan3544's Avatar
06 S-350
Unknown key
So I recently got my s class and when I received it came with 3 keys, 2 regular keys and one fully mechanical looking key and I can’t find any info on it and I was wondering if anyone knew what it is for/ where it goes. For reference I have already tried unlocking all the visible key holes and none of them work
Old Jan 20, 2024 | 09:50 AM
wallyp's Avatar
2003 S500 2007 GL450
Some possibilities:
Locking Lug Bolts.
One of the old "Clubs" - a steel bar, locking the steering wheel.
Some car covers have locks to prevent their theft.
An aftermarket alarm system with a hidden key switch.
Have you tried the factory metal keys hidden inside the key fobs? Does the mystery key look like one of those? Are you familiar with the mechanical trunk/boot lock?
Old Jan 20, 2024 | 10:23 AM
Ethan3544's Avatar
06 S-350
I have looked at the key inside the fob and it looks similar in a way but it is about double the thickness for the mechanical fob key
Old Jan 22, 2024 | 02:31 PM
tusabes's Avatar
Mercedes
Did you take out the metal keys hidden in the top of your key fobs and try those on your door and trunk and glove box?
Old Jan 22, 2024 | 06:50 PM
Ethan3544's Avatar
06 S-350
I have done that, this is a completely separate key
This is what the key looks like
Old Jan 23, 2024 | 10:04 AM
wallyp's Avatar
Well, well! That is a Mercedes key.
I would try it (without forcing!) in each of the four locks, inserting in each direction, and turning in each direction. While I was doing that, I would do the same for each of the metal keys from the key fobs. My first guess is that a previous owner wanted a spare metal key, or that one or more locks have been changed. It is not at all unusual for the trunk lock to be difficult to operate, since that is rarely done, and it is a bit complicated to operate. Lubrication might be helpful.
Old Jan 23, 2024 | 01:10 PM
tusabes's Avatar
Mercedes
That’s not a key for a W-2 20, the owner probably had another Mercedes and put the key on there
Old Jan 23, 2024 | 01:46 PM
suf3r's Avatar
S55
Hello, did some google search and found out this key for:
W124 E Class (1986-1994)
W126 S Class (1986-1991)
C126 S Class Coupe (1986-1991)
W140 S Class (up to 1994)
