Erasing SRS light
Old Mar 1, 2024 | 01:09 PM
randall977's Avatar
CL55
Erasing SRS light
I have an SRS fault, but no codes and I can’t find any modules which are not working. The previous owner fitted a passenger seat emulator, so I wonder if they didn’t erase the fault off the system?
Another thing - I don’t get any seatbelt warnings on the instrument cluster - should I?
Is the only way to clear this fault to use Star?
This comes up on start, ‘1 malfunction’ when I turn the engine off.
Old Mar 4, 2024 | 02:51 AM
tim687's Avatar
CL 600 '00 5.8L V12
Get access to DAS/SDS/Xentry and read out the SRS system
Old Mar 7, 2024 | 03:37 AM
randall977's Avatar
CL55
I bought Xentry and it says that there are no airbag fault codes, either current or stored. This is pretty frustrating for two reasons - I just spent a lot of money on Xentry and I still have the same warning light.
It seems to me that the passenger seat emulator is the most likely cause of the issue. I think it’s one where they reused the plug from the seat sensor. Should I wire the seat sensor back in?
Old Mar 9, 2024 | 08:49 AM
suf3r's Avatar
S55
Yes, in this case disconnect emulator and connect original plug back and check again.
Old Mar 9, 2024 | 09:22 AM
BenzNinja's Avatar
Former Vendor
should have bought BenzNinja and it would have been solved already...
Old Mar 12, 2024 | 07:21 PM
randall977's Avatar
CL55
Okay, I’m getting somewhere with this - thanks to the Xentry…which I’ve just about learnt to use.
I managed to get the error codes to show again and my SRS problem is code 9103 - Driver ignition circuit containing component R 12/3 (drivers squib airbag) resistance to high.
As I understand this is either a fault with the airbag itself or the wiring being damaged at the plug due to the movement of the adjustable steering wheel and the factory loom being too short. I did find that the previous owner had looped two yellow wires under the steering column - I reattached them - they appeared to be the airbag wires?
I have a spare airbag, but I’m a bit scared of it. Am I safe to measure the resistance at R12/3 and then compare it to the one on the car? I think that it should be 3 ohm.
If that checks out then I will test each wire down the column for continuity.
Old Mar 14, 2024 | 12:49 PM
randall977's Avatar
CL55
It seems that testing the resistance of the airbag might be a bit risky. Is there a way of checking if the airbag is okay without discharging it 😅?
