air matic suspension, malfunction
I have a 2008 s550
"Vehicle level controll malfunction" shows up on dash. Airmatic suspension not working. Went through some water puddles, the next day malfunction message comes on. Asked the Mercedes dealer what might be wrong, they want to replace everything. I got Fault code : 5283 and 4544 with coment " recovery time during filling of central reservoir is too long" Any ideas what is wrong and how to fix? thanks Ray |
The fault code (text, I did not check the numbers) refers to a bad compressor that isn't capable any more to fill up the reservoir pressure quick enough. It could also be a leak that kills the compressor efficiency (and kills it physically too after a while because the pump needs to work more often).
Thanks for the reply. I will put in a new compressor and hope there are no leaks in the system. Maybe I can find a compressor from a Co. other than Mercedes for less money
Ray |
You can buy the compressor from http://www.mymercedesparts.com click on this direct link
Part number is: A2213200704 Price from that site is: $252.50
Originally Posted by rayk
(Post 4799954)
Ray |
Don't you warranty?
The blower motor on my S550 07 not coming on can someone tell me what can I do to fix it
Try dinner and a movie.
Originally Posted by Mike5215
(Post 6793955)
I have a lot of success with http://rebuildmastertech.com (they offer lifetime warranty on their products). I have replaced all 4 struts and the air compressor on my car over a year ago and have no problems.
Any updates on this, I know its an old thread.
I get the similar code using my LAUNCH CRP229 scanner, there have been random times when the whole front drops all the way down. Almost everytime i drive, after some time it tells me the air suspension is malfunctioning. |
i have the same problem on my 2009 s350 did you find any fix ?
(Post 6793955)
The problem is not due to compressor, common problem is air reservoir tank, if you clean the tank you will see the crack on the tank, which lead to air leak.
I recently replaced 3 struts, compressor pump, and relay for S350 2010. Done ~ 70kmiles. Earlier I got an airmatic malfunction hence these were replaced and checked for air leakage as well. Now after driving about 1000 miles, malfuction appears. But If I restart it disappears. Again it reappears after few days. Don't understand. I noticed the mechanic has given more 5mm more than the usual gap between the tyre and the body in the rear, could this be the issue?
Much appreciate any info. https://cimg6.ibsrv.net/gimg/www.mbw...db940e08d.jpeg Right Rear https://cimg5.ibsrv.net/gimg/www.mbw...140a7a529.jpeg Left rear |
Originally Posted by rbadri
(Post 7662149)
Much appreciate any info. https://cimg6.ibsrv.net/gimg/www.mbw...db940e08d.jpeg Right Rear https://cimg5.ibsrv.net/gimg/www.mbw...140a7a529.jpeg Left rear https://cimg9.ibsrv.net/gimg/www.mbw...e40973822.jpeg https://cimg4.ibsrv.net/gimg/www.mbw...5b04717e6.jpeg https://cimg1.ibsrv.net/gimg/www.mbw...9c0b12605.jpeg https://cimg0.ibsrv.net/gimg/www.mbw...f74621a50.jpeg https://cimg7.ibsrv.net/gimg/www.mbw...cfc6fbefd.jpeg |
Thanks. Will try. |
Originally Posted by Minh
(Post 7662378)
as I mentioned, most probably of the problem is air leaks on the reservoir tank, see photo below and you can repair the tank or buy a new one. https://cimg9.ibsrv.net/gimg/www.mbw...e40973822.jpeg https://cimg4.ibsrv.net/gimg/www.mbw...5b04717e6.jpeg https://cimg1.ibsrv.net/gimg/www.mbw...9c0b12605.jpeg https://cimg0.ibsrv.net/gimg/www.mbw...f74621a50.jpeg https://cimg7.ibsrv.net/gimg/www.mbw...cfc6fbefd.jpeg |
3 Attachment(s)
(Post 8049470)
I apologize for bringing up this old thread. I had a similar issue with my vehicle recently and the reason why the suspension malfunctioned with the up arrow came out and it turns out that the ADS Valve is faulty, the hard part is I had to replace the air strut too to replace the ADS Valve. I came across an in-depth article that may be worth reading. Search for "Mercedes-Benz Air Suspension Malfunction + UP Arrow on YOUCANIC" and you will see an article that goes over common causes and possible fixes. You can read about it yourself. I hope this information can assist someone else with a similar issue.
