My W221 project..
#251
Chris
Car looks awesome. Btw: I received the exhaust tips yesterday, they look great. Thanks for quick shipment.
Looking at your car, I have 2 questions
1. Where did you get headlights from and how much? Was it easy plug and play (like the LED tail lights) or did you have to do some SAM programming to get it to work?
2. On the rear bumper (I recently bought the same), did you paint silver color on the middle portion or is it something else? If you can post a close up of that rear bumper, would appreciate it.
Great effort again, Cheers!
2. I painted it classic 744 silvermetallic. I though it woul be better and show more than if it was black like the rest of the car.
#252
S320 - R320 - B200
The silver trim on black is simply the best finish combination and makes the car stand out even more!
Post more pictures...
Question though: I take it you have to order a new number plate holder as the old one does not fit the new S65 bumper shape hence why you have it sitting on your dash board?
#254
That is corect in one way yes. But what I am waithing for is a new number plate without the blue Euro flag on it.
It is a bit smaller without it and I HATE number plates in the front and want it as small as I can get leagelly.
Any special pics you want..Dont know what more to show?
#255
S320 - R320 - B200
Is that a Special Edition badge on the front fenders?
More pictures perhaps of the car now in clear day (Sun) light to see it in its entire glory
I have received most of the kit you've supplied so will start my own upgrade soon...
#256
S320 - R320 - B200
Question about your supplied lighting kit and the S65 DRL's as to how they exactly work ?
Do the S65 kit DRL's wired up with the Magic box kit or separately if so how?
Do the DRL’s switch on during the day automatically or do you have to manually turn them on?
Does the lighting dial controller in the car play any part in the functionality of the new lighting apart from switching headlamps on or set to auto when using the new magic box kit?
Do the old fog lamps have to be disabled in “Star” or do they play any part with the Magic box kit?
Finally on the instrument cluster in the dashboard you can set the current method to have your “day time headlights” set to on, does this function work with your “magic box kit” to switch on the headlamps constantly or is this now linked to the DRL lights function?
I’m preparing for my conversion project hence all my questions concerning the lighting functionality (wiring/coding) having seem you’re successfully completed project using the above kit, can you give us more details as to how the lighting connectivity all works as per questions asked above!
Cheers
Cheers
#257
It will show when yu get them right..They are plug n play and work JUST LIKE OEM...Already told you several times.
#258
Rear Spolier Color Combination?
Chris
On the photo below, does the spolier under rear bumper number have original grey color on upper piece and silver on lower piece or did you paint black and silver?
I cannot tell from the photo below - if you can post a close up of rear, that will be great?
[quote=Chris The Swede;5203131]
#260
Not exactly - you said you used silver metallic for the bottom portion of the spoiler but I want to know color of the piece just above that silver part. Is that the unpainted grey color or did you paint it black. That part is not clear from photos.
#262
#264
S320 - R320 - B200
As I have the same kit and getting it sprayed up I believe I may answer that question for you as it comes unpainted in a finished black/grey charcoal finish... You can't really tell from the picture but I would guess he has left it unpainted but a rear end picture would clear this up.
#269
03 SL500 and 08 S550
Chris, awesome job across the board... I'm jealous of our talents... but LOVE your ideas... on your 1st post you did a bluetooth upgrade... what vendor and model did you use? Would this work in the states? Thanks in advance for your comments!
#272
1 Post
4 wheeled car.
LMAO I feel for you Chris and the thousands of questions! To this date, I keep getting PM's about each of my cars with a billion different questions. I guess that's the downfall for being such a trendsetter! :P
#273
1 Post
4 wheeled car.
On a similar topic, has anyone done the AMG programming? Would that just be a Stardiag thing?
http://www.mbscashopen.se/sv/s-klass...rammering.html
#274
I would like to do this.Chris have you ever done this before?
