17" winter rims on 2011 S550 4matic?
Old Jun 13, 2013 | 04:52 AM
CityBoy's Avatar
2020 S63 4matic+
Have anyone tried 17" rims with 235/55/R17 winter tires fitted to 2011 S550?
I have 2011 S550 4matic and I am thinking about getting 17" E-class or C-class rims with ET35 to put 235/55/R17 Hakka7 studded for winter. Should I just stay with OEM 18" rims and 245 rubber? The cost of Hakka7 in 18" is $400 vs $200 for 17" rubber. 17" vs 18" rims cost the same.
On a side note... I have my own set of 16" winter wheels from 2008 E-class. I guess 16" rim just won't fit 2011 S-class.
Thx.
Old Jun 20, 2013 | 11:41 PM
CityBoy's Avatar
2020 S63 4matic+
bump!
Does anyone know if 17" or 16" rims would fit?
Old Jun 20, 2013 | 11:42 PM
CityBoy's Avatar
2020 S63 4matic+
2011 S550 4matic: can i put 17" or 16" rims on this car for winter?
like the title says: would it be possible to get 17" or 16" rims on this car?
Old Jun 21, 2013 | 02:45 AM
marthyh's Avatar
S500
Yes should be fine bc,in winter I am using rims with 235/55/R17 fitted to my 2006 W221.
Its the original wheel-size for my car,later MB started using 18 inch as a standard on W221 afaik.
16 inch is crazy because you will lose proper feeling/control over the heavy car going fast round bends or curves.
Be carefull with the ET-values and widths if you are using wheels from other MB 's: as the wheels may or may not clear brakes and/or wheel-wells.So try them on first,best is to get a set of W221 rims.
Also,as long as you stay within 5 percent of the original outer circumference of the original wheel(including tyre) you're golden.
Old Jun 21, 2013 | 08:30 AM
CityBoy's Avatar
2020 S63 4matic+
marthyh,
thanks a lot.
