B82 Temperature Humidity sensor location
Old Nov 28, 2013 | 07:35 PM
terrymargate's Avatar
merdeces s320
Does anyone know where is sensor is located please (2011 S550)
I cannot find it anywhere.
Also on a more technical note, could a fault here knock out part of the LIN bus and put the system into emergency mode????
Blower was stuck on, replaced blower and regulator, it then had an error message saying error in LIN BUS communication with some stepper motors, blower regulator, B82 Temp humidity sensor and it also told me the b82 was defective.
Blower is in "Emergency Running' Mode according to Star Diagnostics.
I removed all all the dash, located the 4 suspect stepper motors that did not seem to be responding, replaced them and still the problem is the same. Am hoping is the B82 sensor as thats my last option except for cabling.
Everything else seems fine in the ac system, all the other sensors read out correctly and the other stepper motors seem to work fine.
This is a head scratcher, can anyone shed any light here?
