Something I noticed about 4matics and staggering wheels...
On all 07-13 S classes, if you have a 4-matic, all 4 tires and wheels are the "same size".
I just saw a 2015 S550 at the dealer, 4 matic, and it had staggered setup from factory! Mercedes has never done this on the 4-matic, with the OEM setup. I just thought this was cool. Not sure if they had this avail for the 2014, but the 2015 has it.
The overall rolling diameter needs to remain the same or as close as possible. Alot of people say its a big no no to stagger wheels on an awd but I build wheels all the time for AWD setups and its the tires that need to be specifically chosen. On my Wifes IS250 AWD I ran a 20x9/ 20x10.5 and just balanced it out with 245/30/20--285/30/20 tires. I was .7in off and had no issues
SPONSOR
I think a lot of auto manufacturers are doing this now. I believe it is because as the awd systems advance they do not need a non staggered setup to help decrease understeer. Plus a staggered setup looks more aggressive
As for the post above the tires should be 245/35/20 and 285/30/20 for them to be almost the same. That setup will almost have a full inch diameter difference.
I actually ran a 275/30 on the rear. A 285/25 would have been the best but It was tough to find a a complete set of tires with that setup. A 35 series tire would never work on my setup because if the anmount of drop that I had. I had a tough time getting the 245/30 to stop rubbing
I have staggered rims on my 4matic s550. I swapped out my stock 19inch amg rims which rode like butter for the Vossens I had on my old s550 non-4matic. Tires were 255/30/20 in front and 275/35/20 in rear. The car drove fine without problems albeit the Fronts rode very rough. i felt every hole and bump on the roads and lets not mention the heart wrenching "thud" in the front end when encountering unseen/unanticipated potholes.
I drove from Toronto to NY with them and they were fine.Spent 4 days in NY with no problems.
I did notice a scary "sway"/"fishtailing" in the rear which started during my last day in NY and on the ride back to Toronto. not sure if it was an issue stemming from staggered rims on 4matic platform. But it was very scary. Upon encountering any bump on the road, the rear would fishtail noticeably. Even my mom noticed. On a normal car, one could suspect the shocks but my airmatic suspension seemed fine with no apparent leaks. so this scared me. Did some research and found most suggesting it needed a F+R alignment. Others suggested it was bushings. Nonetheless, especially on smooth roads, the car rode flawlessly.
All this was last week.
I had every intention to change my fronts for more cushion especially since I noticed my current front tires were both balding unevenly on their inner sides. So Today, I got new front tires; 255/35/20. And got a 4 wheel alignment. The ride is unbelieveablly so much better with the extra 5% on the sidewall in front tires. And so far the rear doesn't seem to fishtail anymore...fingerscrossed.
Overall, Astonliyarnachi is right, doesn't matter if you run staggered on a 4matic, it will be fine as long as the overall rolling diameter is within 3% of factory spec.
Doesn't seem to be a problem with my set up at least.
This is sort of where I am at right now...I have the AMG 20" and the ride is unbelieveably rough not to mention in less than a year of ownership I have already had bends in three out of four rims due to pot holes. My debate is whether to downsize to 19s. You said the 19s were like butter which is very appealing but I really like the look of bigger wheels. Is there a huge difference between the 20s and 19s?
This is sort of where I am at right now...I have the AMG 21" and the ride is unbelieveably rough not to mention in less than a year of ownership I have already had bends in three out of four rims due to pot holes. My debate is whether to downsize to 20 or 19. You said the 19s were like butter which is very appealing but I really like the look of bigger wheels. Is there a huge difference between the 20s and 19s?
No, lol. I think I had a stroke or something. Let me go back and edit that post...
I have 20s not 21s and I'm wondering if there is a huge difference between the 20s and the 19s. I'm assuming the extra rubber really helps but with the cost involved (including the powdercoating I would do) I want to make sure it is worth the switch.
Oh, and I'm in Northern California and yes some of the streets are HORRIBLE. I've stopped taking Fulton Avenue because of the huge pot holes.
Ok, so you've never driven the 19's? It's probably better I would assume. This one has the 19's, but I drove a friends the other week with 20's and thought it rode great, and in the city too.
I know bigger wheels are in style and I really like the look but I have a long commute every day and ride quailty is important. I guess I'm looking for how much better 19s are vs. the cost to switch. If its not that much better then I will live with the ride and save the money.
I wish MB still offered a spare tire standard on all vehicles, I hate the runflats.
hey
1 Post
2011 Mercedes S63 AMG
Actually MB has done this prior to 2015 with the 4matic CLS & C-class models. Bmw has been offering staggered set up on their xdrive models for some time now including the 7 series as an option on certain models. I think Mercedes decided to step it up this time around and offer the staggered set up on the SClass 4matics. MB does offer a wider tire set up on the 07-13 s-class 4matics then most other car makers, so you won't feel so hard pressed about the staggered set up.
