No Start after ECU tune
Old Jan 9, 2015 | 04:58 AM
ainain's Avatar
S600 2007
I have S600 2007 W221 sent my ECU for tuning to get better performance.Got it today and when i put it back car wont start dash lights come on but nothing happens when i turn the key to position 3.checked the battery its fine when i switch to position 3 fans start running at full speed!
Any suggestions? ECU? car security?
Thanks in advance
Old Jan 9, 2015 | 06:41 AM
lganski's Avatar
2006 S430 4Matic
Welcome to the forum. You will have to have to have a diagnosis done with the star system. Sounds like something was changed that the system does not like.
Old Jan 9, 2015 | 08:33 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Thanks in advance
Triple check that you have the electrical connectors on correctly and fully seated until you hear the click
Old Jan 9, 2015 | 12:09 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Who did you use for the tune?
Old Jan 9, 2015 | 01:30 PM
ainain's Avatar
S600 2007
I asked a friend to check with star but while connecting to ECU it would say "communication error".
Old Jan 9, 2015 | 01:32 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
either tune file is bad or connection is loose...
yea, who did the tune??
Old Jan 9, 2015 | 01:34 PM
ainain's Avatar
S600 2007
Thanks I checked i thought that cable and pins correspond in a way that they won't accept the wrong plug but someone else said the same thing as you said so i might be wrong
Old Jan 9, 2015 | 01:37 PM
ainain's Avatar
S600 2007
ECU photo with connections
Old Jan 9, 2015 | 02:39 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Again....who was the tuner?
Old Jan 9, 2015 | 03:25 PM
loungn14's Avatar
SPONSOR
whenever we have seen this with our tuning, it is due to a connector not being properly seated.
I would remove the ecu and slowly reseat it. Check for bent pins.
You should feel a click when the cable is in tight. Gently pull back as well and make sure it is seated.
